If a specific post was interesting or useful to you, we recommend that you Like that post. It tells the post author, and others, that you found the information valuable. Clicking Like is another way to let others know that you enjoy it without leaving a comment.
Log in to join the conversation and Like this content.
Nikki (Dec 4th 2023) |
Total Likes: 1 |
Re: Motorschaden in Terrace B.C. Kanada
#705079
Dec 4th a 04:12 AM
von WV40.10 |
WV40.10 |
Also, habe mich an Dapo gehalten... ‐---------- Hallo Andreas,
das Paraflu 11 hat u.A. die Freigabe Chrysler MS7170. Auch die MB 325.0 ist relativ ähnlich. Damit sollte sich doch was finden lassen.
Die Farbe sagt nicht allzu viel aus, manche Hersteller färben das blau ein, andere grün. ----------
Und bin bei:
STP® Universal Antifreeze/Coolant is a superior quality ethylene glycol based engine coolant with a low silicate corrosion inhibitor package. This product protects coolant system metals, including heat-rejecting aluminum, against pitting caused by cavitation and corrosion. It provides exceptional cooling in summer and excellent protection against freezing in the winter. It is recommended for use in older model domestic and foreign cars and light duty trucks and will provide up to 80,000 km or 2 years service life when installed as initial fill, or after a complete flush and cleaning of a cooling system in reasonable condition. - For domestic & foreign cars & light duty trucks - Meets the performance requirements of ASTM D-3306, D-4985; GM 1825M, 1899M; DaimlerChrysler MS7170; TMC RP 302B; Ford ESE-M97B44-A - 3.78 L
Gelandet, low silicate war neben den aufgezählten Normen das ausschlaggebende Zauberwort... Ist nebenbei auch schön grün...
Außerdem gab es in dem Nest in Kanada auch nichts anderes ... bzw alles andere hatte ca. zwei Wochen Lieferzeit.
LG Andreas
149
Themen44,280
Posts672,078
Mitglieder9,909
