Posts: 39 |
hallo, I dont know what this lever is for, please can someone tell me, bitte?
Posts: 7,490 Likes: 109
Posts: 7,490 Likes: 109 |
is it this one - split ?
Posts: 39 |
danke maybe it is for a pump or similar item? / vielleicht ist es für eine Pumpe oder ein ähnliches Objekt?
Posts: 325 |
danke maybe it is for a pump or similar item? / vielleicht ist es für eine Pumpe oder ein ähnliches Objekt? "A" = Lever to engage front axle, can even be engaged while driving straight ahead,with clutch using "B" = 1:1,3 synchromeshd semi-reduction, shiftable while driving, with clutch using "C" = Low reducer 3:1, to shift, truck has to be stopped The lever for the gear-box or reducer PTO ist foreseen where the black cap beside the lever "C" is located.
Posts: 39 |
thank you again for the excellent explanation Christian.
I removed the dashboard very easily after you told me where the bolts were.
Moderated by
Burgerfrau,
DaPo,
Dieter,
Flashman,
juergenr,
Monny,
Ozymandias,
Peter,
Phil,
rovervirus,
Tordi
1 members (WoMoG),
266
9,904 Registrierte Benutzer |
Themen44,266
Posts671,900
Mitglieder9,904
