Posts: 23 |
Sorry Im write in English. I have a G290TD -00 witch make me confuesed,its have a real bad noice in engine. After few houeres search I found the problem. Its the bracket witch hold up the AC-pump witch broke down near to a bolt. Its that a common problem on this engine and did it happening for anyone else owner on a G290?Thanks a lot all G experts
Posts: 789 |
Hi , Can tell you about my experience with my 290GD when I bought it in Nigeria a couple of years ago . I had the same problem - the aluminium bracket of the ac compressor broke and not only once . Later I found out that the blacks changed the bracket and fixed it properly , but they did not pay attention that the aluminium bracket itself is supported by ( I think 2 ) other smaller brackets to the engine . Check in EPC and you will find what I am talking about .
Hope it will help you !
Regards from Kiev !
1 members (duli),
534
Themen44,261
Posts671,847
Mitglieder9,903
