I was wondering,,, does anyone of you have the experience of changing the leaf-springs on the rear axle. Can I buy and change one single "leaf" ?? Do you have the blueprints of the leaf-springs ? Regards ! Þorleifur.
as far as I know you can get single leaf-springs only for the replacement of the big ones (1st and 2nd leaf from top), not the smaller ones. Unfortunately my 2nd computer is down at the moment so I cannot look into my parts catalogue.
normally (for almost every other truck) you can get every single leaf. I don´t know what´s the matter with Iveco but I think it should be the same here.
But even if not, it is possible to take, for example, a longer leaf and cut it to the length needed; we did that a couple of times with the springs of MAN 26 ton trucks: we 'recycled' broken long leafs to shorter ones...
Thanks for the infos, and Juergen thank you for the blueprints. I will simply ask all companys selling leaf-springs if they have this particular size of leaf I need. Regards Þorleifur. http://www.angelfire.com/ok5/hraunfossar/myphotos/
