#83973 03/03/2006 20:01
hekla Offline OP
Hello Iveco driver !
I was wondering,,, does anyone of you have the experience of changing the leaf-springs on the rear axle.
Can I buy and change one single "leaf" ??
Do you have the blueprints of the leaf-springs ?
Regards ! Þorleifur.
Kabriofahrer
Kabriofahrer
Hi Þorleifur,
as far as I know you can get single leaf-springs only for the replacement of the big ones (1st and 2nd leaf from top), not the smaller ones.
Unfortunately my 2nd computer is down at the moment so I cannot look into my parts catalogue.
Hallo Þorleifur,
here is the blueprint of the rear springs
Juergen
313267-Bildtafel.pdf (0 Bytes, 46 Downloads)
Online Content
Hello,
normally (for almost every other truck) you can get every single leaf. I don´t know what´s the matter with Iveco but I think it should be the same here.
But even if not, it is possible to take, for example, a longer leaf and cut it to the length needed; we did that a couple of times with the springs of MAN 26 ton trucks: we 'recycled' broken long leafs to shorter ones...
hekla Offline OP
Thanks for the infos, and Juergen thank you for the blueprints.
I will simply ask all companys selling leaf-springs if they have this particular size of leaf I need.
Regards Þorleifur.
http://www.angelfire.com/ok5/hraunfossar/myphotos/
Diethard
Diethard
67240 Bobenheim
17,583,760 Hertha`s Pinte
7,411,203 Pier 18
3,494,570 Auf`m Keller
3,336,522 Musik-Empfehlungen
2,511,714 Neue Kfz-Steuer
2,322,569 Alte Möhren ...
0 members (), 461 guests, and 0 robots.
marcus 2
GW350 2
oldie 1
Troll 1
9,894 Registrierte Benutzer
DaPo 26,375
Ozymandias 16,233
Posts671,703
