Posts: 7,478 Likes: 105
Posts: 7,478 Likes: 105 |
Ein Ersatzinjektor ist bei einem 6.0 leider Pflicht. cry das mag ja sein, aber wenn das Steuergerät ein elektrisches Problem an einem Injektor meldet, würde ich doch mal die Leitungen vom STGR zum Injektor und die Widerstände der beiden Spulen im Injektor (zumindest im Vergleich zu den anderen) messen.
Posts: 94 |
Bin eh schon umgezogen...ich wohne ja dauerhaft in meiner Kabine
das hat jemand geschrieben, der sich wohl mit der Materie auskennt - Quellezum Thema "6.0L Power Stroke Engine and Drivetrain > Injector 4, circuit low." First, a little lesson as the codes can tell you what to look for. The FICM controls power and ground for the injector coils by activating drivers for the power and ground circuits for the injectors. The FICM measures the current on each circuit to determine if an injector coil is open or shorted.
Open injector coils and open injector coil power or ground circuits produce low current which sets injector circuit low codes
Shorted injector coils or shorts to ground on the injector coil power circuits produce high current which sets injector circuit high codes
In this case, the DTC P0270 indicates that injector #4 is not drawing the expected amount of electrical current when actuated. Since a low current condition exists we know that there is an open in a circuit somewhere. It could be EITHER power or ground circuit on EITHER coil, the open coil or the close coil. This includes the harness, both coils, and the FICM itself. My experience is that a single injector low code typically ends up being the injector and a harness issue the next likely cause. It is rare that a FICM would cause a single injector low DTC and I recall seeing that maybe once or twice over the years.
You can disconnect the harness at the suspect injector and measure the resistance of each coil to determine if they are electrically open. Measure between pins 1 and 2 for the open coil and pins 3 and 4 for the close coil. A typical reading is about 0.8 to 1.0 ohms which is in the middle of the specs. You can find pin numbers on the face of the connector molded into the plastic and they are very small. A light and a magnifying glass might help you read them. If either coil does not meet specification the injector is bad and needs to be replaced. If the coils test good then you need to test the harness circuits. If those test good the FICM is suspect.
Posts: 94 |
Gestern ist der neue Injektor gekommen, heute wird eingebaut...bin mal gespannt ob dann wieder alles so funktioniert wie es soll.
Posts: 8,093 Likes: 115
Posts: 8,093 Likes: 115 |
hast du ihn mal nur elektrisch angeschlossen und lose nebendran gelegt beim click test? Wenn du den Injektor ausbaust: Ich sauge bei solchen Arbeiten immer den Injektorsitz ab. Ich habe mir dazu einen Adapter für den Staubsauger gebaut worauf ich einen 5 oder 6 mm Benzinschlauch stecken kann. Ich sauge auch den Brennraum aus, falls etwas Diesel / Öl reinläuft.
Posts: 94 |
Verdamte Scheisse, Injektor getauscht, noch immer selber Fehlercode wie vorher. Blwibt nur noch die Verkabelung oder FICM.
Schau mal was bei Beitrag Nr.5 steht. Der Injektorkauf ist kein Fehler, lege ich mir auch noch zu, weil man als 6,0-Fahrer sowas einfach brauch.
Hast du den Turbo ab damit du besser die Kabelstränge untersuchen kannst?
Frag mal in der Superduty-Gruppe, ich meine da ist jemand aus Ö. Evtl. kann er die alles auslesen. Ich bin hier zu weit weg.
du hast jetzt den Injektor eingebaut oder nur angestöpselt?
Posts: 94 |
Ich hab jetzt einen komplett neuen Kabelbaum von FICM zu den Injektoren bestellt und gleich auch eine neue Doorman FICM Platine...damit muss das Problem gelöst sein. Alles was am Ende über bleibt heb ich als Ersatzteil auf.
Danke für eure Beiträge, bis auf die Scheuerstellen kannte ich die schon.
552
Posts671,700
