#83973 03/03/2006 20:01
hekla Offline OP
Hello Iveco driver !
I was wondering,,, does anyone of you have the experience of changing the leaf-springs on the rear axle.
Can I buy and change one single "leaf" ??
Do you have the blueprints of the leaf-springs ?
Regards ! Þorleifur.
Kabriofahrer
Kabriofahrer
Hi Þorleifur,
as far as I know you can get single leaf-springs only for the replacement of the big ones (1st and 2nd leaf from top), not the smaller ones.
Unfortunately my 2nd computer is down at the moment so I cannot look into my parts catalogue.
Hallo Þorleifur,
here is the blueprint of the rear springs
Juergen
313267-Bildtafel.pdf (0 Bytes, 46 Downloads)
Hello,
normally (for almost every other truck) you can get every single leaf. I don´t know what´s the matter with Iveco but I think it should be the same here.
But even if not, it is possible to take, for example, a longer leaf and cut it to the length needed; we did that a couple of times with the springs of MAN 26 ton trucks: we 'recycled' broken long leafs to shorter ones...
hekla Offline OP
Thanks for the infos, and Juergen thank you for the blueprints.
I will simply ask all companys selling leaf-springs if they have this particular size of leaf I need.
Regards Þorleifur.
http://www.angelfire.com/ok5/hraunfossar/myphotos/
May
M D M D F S S
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
17,639,721 Hertha`s Pinte
7,426,420 Pier 18
3,499,991 Auf`m Keller
3,347,803 Musik-Empfehlungen
2,516,881 Neue Kfz-Steuer
2,332,123 Alte Möhren ...
0 members (), 272 guests, and 0 robots.
WoMoG 2
Caruso 1
Darktime, Hehomarco, Dzakob, Egika, king463
9,897 Registrierte Benutzer
DaPo 26,380
Ozymandias 16,236
Themen44,256
Posts671,771
Mitglieder9,897
