#583622 04/01/2014 23:13
Redd Offline OP
hallo,
I dont know what this lever is for, please can someone tell me, bitte?
[Linked Image von i.imgur.com]
is it this one - split ?
Redd Offline OP
danke
maybe it is for a pump or similar item? / vielleicht ist es für eine Pumpe oder ein ähnliches Objekt?
[Linked Image von i01.i.aliimg.com]
Original geschrieben von Redd
danke
"A" = Lever to engage front axle, can even be engaged while driving straight ahead,with clutch using
"B" = 1:1,3 synchromeshd semi-reduction, shiftable while driving, with clutch using
"C" = Low reducer 3:1, to shift, truck has to be stopped
The lever for the gear-box or reducer PTO ist foreseen where the black cap beside the lever "C" is located.
Redd Offline OP
thank you again for the excellent explanation Christian.
I removed the dashboard very easily after you told me where the bolts were.
Gillib
Gillib
Oberösterreich
19,400,121 Hertha`s Pinte
7,765,318 Pier 18
3,648,250 Auf`m Keller
3,540,164 Musik-Empfehlungen
2,635,994 Neue Kfz-Steuer
2,552,496 Alte Möhren ...
0 members (), 370 guests, and 0 robots.
Caruso 2
Gunnar 2
duli 1
Splintbolzen
Beast_on_walkabout, Snoppy, ThomasT86, Magehr, DaDos500
9,997 Registrierte Benutzer
DaPo 26,491
Ozymandias 16,514
Themen44,445
Posts674,070
Mitglieder9,997
