Posts: 39 |
hallo, I dont know what this lever is for, please can someone tell me, bitte? ![[Linked Image von i.imgur.com]](http://i.imgur.com/HM2Etl8.jpg)
Posts: 7,596 Likes: 128
Posts: 7,596 Likes: 128 |
is it this one - split ? ![[Linked Image von thumbs.picr.de]](http://thumbs.picr.de/16956791rx.jpg)
Posts: 39 |
danke ![[Linked Image von i.imgur.com]](http://i.imgur.com/vEWL3DE.jpg) maybe it is for a pump or similar item? / vielleicht ist es für eine Pumpe oder ein ähnliches Objekt? ![[Linked Image von i01.i.aliimg.com]](http://i01.i.aliimg.com/photo/v0/115742621/PTO_ZF_6_S_300_6_S.jpg)
Posts: 325 |
danke ![[Linked Image von i.imgur.com]](http://i.imgur.com/vEWL3DE.jpg) maybe it is for a pump or similar item? / vielleicht ist es für eine Pumpe oder ein ähnliches Objekt? ![[Linked Image von i01.i.aliimg.com]](http://i01.i.aliimg.com/photo/v0/115742621/PTO_ZF_6_S_300_6_S.jpg) "A" = Lever to engage front axle, can even be engaged while driving straight ahead,with clutch using "B" = 1:1,3 synchromeshd semi-reduction, shiftable while driving, with clutch using "C" = Low reducer 3:1, to shift, truck has to be stopped The lever for the gear-box or reducer PTO ist foreseen where the black cap beside the lever "C" is located.
Posts: 39 |
thank you again for the excellent explanation Christian.
I removed the dashboard very easily after you told me where the bolts were.
Themen44,493
Posts674,644
Mitglieder10,027
