Redd Offline OP
bremach - Ist der Fahrzeugrahmen verdrehen?
does the frame of the breach flex much?
do i need to build the camper chassis to compensate?
[Linked Image von farm4.static.flickr.com]
Die Broschüre sagte, der Rahmen sei sehr starr. Ich baue den Körper für das Fahrzeug und möchte wissen, ob der Rahmen sich dreht.
Th e brochure says the frame is very rigid. I am working with the frame at the moment and it is very well made, very well aligned.
[Linked Image von i.imgur.com]
Entschuldigungen für das Sprechen Deutsch, ich benutze Google Übersetzer.
Hi Redd,
no he does not
no - the most Camping-boxes on Bremach are mounted directly on the Frame, using silent bearings to compensate the torsion caused movement
In 2012 Erich Christ wrote in this thread (link fixed)
Original geschrieben von Erich Christ
BREMACH frame wheelbase 3000/3100 mm (Extreme from 2007 and T-REX), with front axle load 2300 kg and rear 3200 kg, two wheels diagonally lifted. Frame twist about 2-2.5 mm
For wheelbase 3400/3450 (Extreme from 2007 and T-REX) mm approx. 2,5-3 mm (same axle loads).
At the outer edge of the frame (tube), ie at a frame width of 770 mm, this is approx 4 mm (up & down). Which must be able to accommodate the silent bearings.
Redd Offline OP
Thank you, I really appreciate the information! Das ist eine sehr gute nachricht.
The link you posted is broken, I would love to read it. The German language version would be fine.
Timex_TLS
Timex_TLS
Südfrankreich 31
May
M D M D F S S
1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
19,866,696 Hertha`s Pinte
7,843,359 Pier 18
3,693,304 Auf`m Keller
3,598,311 Musik-Empfehlungen
2,668,400 Neue Kfz-Steuer
2,597,052 Alte Möhren ...
3 members (Matti, 2 unsichtbar), 260 guests, and 0 robots.
GSM 5
PeterM 5
Dbrick 3
Monda, SebBen89, IVO 4x4, leirob, Mikel
10,037 Registrierte Benutzer
DaPo 26,555
Ozymandias 16,654
Themen44,510
Posts674,942
Mitglieder10,037
