Kabriofahrer
Kabriofahrer
Hallo Leute,
eben erreichte mich folgende Mail:
Hello Bernhard,
I am writing from Australia and hope you can translate to English without too much trouble.
I live in Australia and have an Iveco 4x4 4010 campervan with a burnt out engine.
I am wondering if you know of anywhere in Europe who would carry a reconditioned engine or have an engine out of a wrecked vehicle.
This model is not common in Australia and this is why I am having so much trouble to find a replacement engine.
Thanking you
Also:
der Mann sucht offenbar jemand, der wahlweise
  • seinen Motor aufarbeitet oder
  • einen Motor aus einem zur Verschrottung anstehenden Fahrzeug hat
Hat jemand 'ne Idee?
Hi Berni
Schreib ihm er soll sich einen ganz normalen Zahnriemenmotor suchen, die gibts da unten auch und sind wohl tatsächlich viel eher zu finden als der 4x4-Spezial.
Passen tut der einwandfrei, er soll bloss darauf achten das die Baujahre in etwa übereinstimmen.
Kabriofahrer
Kabriofahrer
Danke, Ozy,
ich hatte ihn zunächst auf diese Seite verwiesen, inzwischen hat er mir mehr Infos und die Fahrgestellnummer gemailt, ist ein 1999er-Modell, Motor an Überhitzung gestorben wg. Leck im Kühlsystem...
Thank you for your interest and help. We had a look on the web at the Iveco
you
mentioned. It would be good to know the age of the vehicle. I guess we
should email the owner as you suggested.
The Vin/Chassis No. of our vehicle is ZCFD4079205183512: 1999 Model (ours
is a campervan)
We believe there are only 25 of the 4x4 models in Australia. They were
imported by Britz, a car rental co. and fitted out as campervans. Britz
sold them on fairly quickly, maybe they werent popular as they fitted 4
people sleeping but with not much room to spare.. will send a photo of ours
with this.
The only problem we had with our vehicle, prior to the engine overheating
due to a hose breakage..was the speed on highways.. as above 100 km/per
hour was not comfortable as the engine seemed to overrev.. we believe this
can be overcome by larger diameter tyres. Without checking (the car is
presently at the garage) we believe we had 750 R16 Pirelli tyres fitted.
I've attached some photos of our Iveco in case you're interested.
Werde ihm deine Empfehlung geben.
Kabriofahrer
Kabriofahrer
Wollte Euch noch die weitere Entwicklung wissen lassen:
We have almost decided what to do about the engine for the 4x4 Iveco.. after
much searching the easiest,cheapest and we hope the best (what do you
think?) solution seems to be a new engine from China ????? it will cost us
only $US 3800.00 and with a good exchange rate $A against the $US it is
cheaper than a second hand engine, even if we could find one in Australia.
We thank you very much for the information you sent to us as this has been
very useful in identifying the engine..no one in Australia seemed to know
all the identifying numbers. Not even Iveco.. it's very small here.
We would be interested to know your opinion on engines from China. We
haven't placed an order yet but they do have the exact model.
We really enjoyed the web page with all the different campervan layouts..
they are all such bright colours.. we only see white in Australia.
Cheers for now
Jacques
Die erwähnte chinesische Firma ist zu finden unter dieser Adresse, was haltet Ihr davon? (... falls mal einer einen Motor braucht ...)
Ich glaube das er da einem Irrtum aufliegt, er wird da keinen Kettenmotor bekommen, nur den mit Zahnriemen.
Was ja aber kein Hinderungsgrund sein muss, im Gegenteil.
Interessant ist das auf jedenfall, die Firma sollte man vielleicht im Auge behalten, so ein 2.8er Intercoolermotor würde mir schon passen wenn man ihn bezahlen kann.
Kabriofahrer
Kabriofahrer
... hab da noch einen gefunden: Krausmotor
Kabriofahrer
Kabriofahrer
aus 'ner e-mail:
Ich kann sehr günstig einen sehr gut erhaltenen
IVECO 40-10W kaufen. Nur ist kein Motor vorhanden.
Und auch keine Daten über den vorher eingebauten
Motor. Daher meine Frage: Weißt du, welche Motoren
(Modelle) ich in den Iveco einbauen könnte?
Werde den Absender mal auf die diversen Freds hier verweisen ...
M Offline
Hi Leute
Warum will der Aussi einen Motor um die halbe Welt transportieren, wenn es in Australien Top Instandstellungsbetrieb gibt. Wir hatten 1992 einen Motorschaden im Outback (LR109 mit Peugeot Turbodiesel). Es ist billiger und schneller, die benötigten Teile zu versenden, als gleich den ganzen Motor.
Wäre das nicht eine Alternative?
Gruss Rene
Kabriofahrer
Kabriofahrer
Nun, der Australier vor 2 Jahren hatte wohl einen Totalschaden wegen Überhitzung (Kühlerschlauch durch und Wasserverlust in kürzester Zeit), da ist's wohl mit ein paar Teilen nicht getan.
Aktuell geht's um ein Fahrzeug hier in Deutschland, was offenbar in sehr gutem Zustand ist, aber eben ohne Motor ... wie gesagt, bisher nur eine Anmerkung, noch keine konkreten Fragen ... hab's halt hier mal angefügt, um den Fred mit den diesbezüglichen Infos wieder nach vorn zu holen.
Stephan
Stephan
Köln
20,343,377 Hertha`s Pinte
8,019,535 Pier 18
3,783,986 Auf`m Keller
3,724,145 Musik-Empfehlungen
2,747,074 Neue Kfz-Steuer
2,706,539 Alte Möhren ...
0 members (), 403 guests, and 0 robots.
Phil 6
tasso 3
Jens 1
bleyhuette, Gaditano, Burkhard, Leuchtdichte, G-o-test
10,110 Registered Users
DaPo 26,640
Ozymandias 16,750
Topics44,405
Posts675,684
Members10,110
