#572474 23/09/2013 22:13
Hallo all
I know the words we use for components are different.
Is this normal? - the leaf spring and the tie-rod seem too close
[Linked Image von i.imgur.com]
Redd #572477 24/09/2013 00:36
J
Irgendwoher aus dem Westen
J Offline
I do not know where your Bremach comes from. I t seems to me that the Springs are the problem.
on the spring in the front ( right side) i see 3 blades an on the other side (Left side) but i can only see 2 blades. Are the blades clamped together? as there is much room between the blades.
They are flat , they should be Hollow ( see picture) , do you have the 2 shackles on both ends ?
Spring
Redd #572510 24/09/2013 08:49
Ich seh auf der linken Seite aber auch 3 Blätter.
Für mich sind die Federblätter verschliessen. Er hat ja schon Luft zwischen den einzelnen Blättern. Zudem ist es vom Achsaufbau noch ein T-Trek...er dürfte garnicht so tief liegen!
Micha
Redd #572585 24/09/2013 18:41
If I look at this picture of the front axle assy I would say that the springs are worn.
http://www.trucktrend.com/roadtests/ultimate/163_1106_bremach_t_rex/photo_10.html
Iveco 40-10WM1
Redd #572667 25/09/2013 06:50
A Offline
Original geschrieben von Redd
Hallo all
This front springs are deformated (= heavy overbended in the rear half of the spring), usually as a result of heavy jumps.
The deformated aluminium noise protection plate on bottom of the t-rod speaks even for this scenario.
Thats the main reason why the distance between the t-rod and the spring is too small.
Note: This kind of parabolic springs very seldom breaks when oberstressed, mainly stay constantly deformated as shown on the pic.
I can even see the triangle reinforcement on the outer knuckle, which was a modification only done by Allrad-Christ, so I assume this is an ex-Rheinbraun truck from one of their coal mines.
So the t-rod problem could even be increased by a worn out upper knuckle bearing, creating too much play. One of the usual problems on this vehicles.
Redd #572796 25/09/2013 23:10
Danke
good information!
bad news!
yes it was a mining vehicle
here are some more pictures. I think i will get the spring's re-heated and re-formed
http://i.imgur.com/MG3VXpy.jpg
http://i.imgur.com/jWxbzWJ.jpg
http://i.imgur.com/Z6b3Eu8.jpg
http://i.imgur.com/euHXdWF.jpg
http://i.imgur.com/i2mSwKc.jpg
http://i.imgur.com/qeIxjcU.jpg
Redd #572974 28/09/2013 06:13
Looks like you got a huge frame project ... My condolence !
Gruß Michel
Redd #572975 28/09/2013 07:00
Hi redd
please use this server for your pictures in this forum
www.picr.de
its very easy and your pictures will be displayed automatically in the thread.
thanks
Nobelhobel
Nobelhobel
Hi Ozy
I believe it's not the server, it's that redd should insert a (non-floating) picture into his post rather than a link to a picture, e.g. for http://i.imgur.com/MG3VXpy.jpg:
q.e.d
oliver
Redd #572991 28/09/2013 11:34
ha!
no, I was at work, and no time to make the pictures smaller.
so i linked to them, because they were too big for the forum.
the frame is okay. we have been looking at it for two days and can find no deformation.
have started to take the front apart. I think i will take the cab off and restore it properly.
schoeni
schoeni
Landkreis Heilbronn
20,775,101 Hertha`s Pinte
8,180,795 Pier 18
3,897,302 Auf`m Keller
3,858,888 Musik-Empfehlungen
2,859,018 Neue Kfz-Steuer
2,833,307 Alte Möhren ...
0 members (), 777 guests, and 0 robots.
WoMoG 6
G300GD 1
atolex 1
10,176 Registered Users
DaPo 26,723
Topics44,506
Posts676,956
Members10,175
