Posts: 7,634 Likes: 133
Posts: 7,634 Likes: 133 |
ja der sieht viel besser aus, ein paar Fragen / Anmerkungen 2019 aufgebaut und warum jetzt wieder verkauft The Iveco has 200000 km which is little for this engine. - nun ja, 200tkm ist zumindest mehr wie eingefahren... Complete overhaul with new radiators, intercooler and turbo - ah ja - warum das. - der hat ein "chiptuning" > 215ps - normal beim älteren F1C wären 125 kW (170 PS) - der hat keine Türe im Koffer, also immer durchs Fahrerhaus - wer hat den Koffer aus was, wie gebaut und wie befestigt ? - was wiegt er, reisefertig ?
Posts: 24 |
Ich kopieren mal hier die Frage-Antwort Kommunikation mit dem Verkäufer rein....
- Why do you sell the vehicle? change of professional acitivities of my partner - where did you travel with the car? Marokko, Portugal, Spain, Italy, Austria - "Iveco's 1. Life" = garden. What does that mean? garden maintenance as pickup - What happened that the car needs "Complete overhaul with new radiators, intercooler and turbo"? Maintenance, and to be sure when driving in remote area's. Invoices Iveco. - Chip tuning to 215PS: Did you do it, why? i am sorry the car is not tuned! it is still as is was from factory; i did not know the PS exactly as a layman 🕵 - How heavy ist the vehicle with all stuff ready to travel +/- 4 tons - How much l/km normal driving?15-16 l - alpha motorhomes build the furniture you said - who built the suitcase out of what, how and how was it attached? Do you have pictures how the suitcase is attached? yes. Alu sandwich panels 6cm , roof 10 cm , bottom 15 cm! The cabin and overbuilt are all fixed on chassis and doka. I will look for foto's (2018) - Do you have an official invoice for the expansion? Yes, camper is homologated in belgium as a camper, no problem.
Posts: 670 Likes: 47
Posts: 670 Likes: 47 |
Also das was man im Video sieht schaut mir stellenweise doch sehr nach "Let's go to the Baumarkt and buy something to bastel..." aus.
Posts: 5,756 Likes: 98
Posts: 5,756 Likes: 98 |
Stimmt den folgende grobe Rechnung: Baujahr 2008 + 210000km, das Basisfahrzeug würde ich je nach Zustand auf 25-35t€ schätzen. Leere Kabine mit Alkoven 25T€ - dann blieben für den Innenausbau von 2019 30-40T€ zu veranschlagen - macht insgesamt die 90T€. Klingt irgendwie passend, oder überseh ich etwas? Satter Preis! Klar, der Fernseher mit Satschüssel, ohne den man heutzutage scheinbar nicht mehr reisen kann, ist auch noch was wert  Das Fahrzeug scheint auf den ersten (fern) Blick OK. 200t Km finde ich auch nicht grad "nichts", aber auch noch nicht kritisch viel. Der etwas heikle Garret-VTG-Turbo des F1C E4 wurde schon gewechselt, Wasser- und Ladeluftkühler auch... Hm... Und von der Luft-Zusatzfederung halt ich nicht wirklich viel. Für mich hat der Wohnaufbau zu viel Firlefanz, was den Betrieb verkompliziert und auch störanfällig macht. Aber ich bin ja nicht das Mass-der-Dinge und man kann (wenn es denn wirklich zickt oder stört) Rückbauen. Hab ich das richtig gesehen, der schleppt neben einem Reserverad noch zwei Reservereifen mit sich rum, dazu 300 Liter Diesel und 200 Liter Wasser? Die 4 Tonnen glaub ich nie und nimmer nicht!Einstieg lediglich durch die Fahrerkabine find ich zwar nicht optimal, geht aber. Scheinbar lässt sich der Durchgang zur Fahrerkabine nicht verschliessen. Das ist schlecht! Bei Reisen in kühle Regionen verlierst viel Wärme durch das unisolierte Fahrerhaus und zudem wird es zur Kondenshütte. Bei Reisen in warme Gebiete wird es in Fahrerhaus wegen der Glasflächen auch leicht mal >50° Warm. Kann man den Durchgang nicht verschliessen, wird es unnötig heiss im Wohnaufbau.
Posts: 1,460 Likes: 39
Reisender
Reisender
Posts: 1,460 Likes: 39 |
[quote=HighCo Power Die 4 Tonnen glaub ich nie und nimmer nicht! Das kann ich auch nicht glauben. Das kommt mir eher vor wie das Wunschleergewicht. Frag ihn doch mal nach dem Leergewicht. Und der Einstieg durch das Fahrerhaus mit dem Notsitz ist für mich auch nur die Zweitbeste Lösung. Auf jeden Fall sind die 90T für das Fahrzeug kein Pappenstiel. For the sake of clarity, camper with driving license C is free of speed limiter and road pricing (obu) as well as the tachograph.Da soll er mal nach Österreich oder so fahren, dann wird er schnell eines besseren belehrt wenn er Lkw-Tarif auf der Autobahn zahlt. No hassle with overloaded driving because this 4x4 can handle a lot.Warum bezieht er sich darauf dass man das Fahrzeug Überladen fahren kann wenn es doch nur 4 To reisefertig hat. Gruß, Horst
lt Technischer Beschreibung hat der 55S18DW (Doka) 2765kg Leergewicht mit 9,5erR17.5er Bereifung, bei serienmäßige Ausführung ohne Sonderwünsche.
Die angegebene Leistung von 215PS muss er als Laie (Layman) ja irgendwo gelesen haben, am ehesten in den Fahrzeugpapieren ...
p.s. die weißen Silikon Nahtabdichtungen die man im Video sieht, sehen nicht sehr schön aus. Ob das Rückschlüsse auf die allgemeine Verarbeitung des Ausbaus zulässt, weiß man natürlich nicht.
lt Technischer Beschreibung hat der 55S18DW (Doka) 2765kg Leergewicht mit 9,5erR17.5er Bereifung, bei serienmäßige Ausführung ohne Sonderwünsche. Ich tipp eher auf reisefertig +/- 5 Tonnen und damit nicht weit vom Limit. Passt auch zur Zusatzluftfederung. Ein "versehentlicher" Vertipper, wie bei der Leistung?
Posts: 646 Likes: 24
Posts: 646 Likes: 24 |
Er schreibt ja +/- 4 tons...es wird eher plus als minus sein und das nicht zu knapp...wie bei jedem Womo...
Besteht wirkliches Kaufinteresse ist das einzig richtige das Teil anzuschauen. Vorher überlegen was da sein muss, was nicht sein darf und wohin man damit will was schlussendlich auch Einfluss auf diese beiden Fragen hat. Dann am bessten mit jemandem der zumindest schon einige (Reise-)Erfahrung mit ähnlichen Fahrzeugen hat anschauen. Danach einige Zeit darüber schlafen, die Rosarote Brille ablegen und die Pro und Contra aufschreiben. Was für den einen ein Nogo ist ist für den anderen ein Must. Dabei auch Folgekosten für Reparaturen und Unterhalt und allfällige Umbauten berücksichtigen. Dann anhand der Liste überlegen ob das einem 90k€ wert ist. Und vor allem das Teil vor dem unterschreiben des Kaufvertrages auf die Waage fahren denn der Verkäufer wird da alles mögliche Schönreden. Wenn sich da noch keine Ernüchterung breitgemacht hat, eine ehrliche Liste mit den Gewichten welche da noch dazu kommen werden um Reisefertig zu sein erstellen. Ansonsten wird Frust wohl vorprogrammiert sein.
Der Vermerk zum C Führerschein (wobei C1 auch schon ausreichen würde) und Tachograph ist nur ein Hinweiss damit der Käufer nicht hinterher sagen kann er hätte nicht gewusst dass B nicht reicht und auch nur dass es keinen Tachografen oder Kartenlesegerät (und somit das Thema Ruhezeiten usw wegfällt) oder dass es keinen Geschwindigkeitsbegrenzer hat, so verstehe zumindest ich das. Maut ist eine ganz andere Baustelle von welcher ich da nichts gelesen habe.
Gruss Urs
Posts: 16,727 Likes: 341
Posts: 16,727 Likes: 341 |
Einstieg ausschliesslich durch das Fahrerhaus ist doch ein völliges K.O. Kriterium! Habt ihr euch das mal überlegt? Mal bildlich vorstellen wie man da mit Bier in der Hand oder so raus geht? Und wie oft geht man rein/raus? 30x am Tag wenn das Wetter stimmt.
Das Ding kannst würfeln.
So krass würde ich das nicht ausdrücken. Ich kenne Leute die haben sich bewusst für eine solche Bauweise entschieden und die sind happy damit. Der Raumgewinn ist nicht unerheblich...aber es ist nicht jedermanns Sache. Meine wäre es auch nicht. Darum gründlich überlegen ob für einem selber passt. Wenn man zum Schluss kommt dass man damit leben kann, dann kann man es ja immer noch für die Preisverhandlung als Minuspunkt in die Waagschale werfen.
Gruss Urs
1 members (AndreasHannover),
334
Posts675,972
