Posts: 9,015 Likes: 3
Posts: 9,015 Likes: 3 |
hat jemand schon mal bei denen was bestellt? http://www.greatbasinrovers.com/aboutset.htmlwie läuft das mit zoll und mwst bei einer bestellung in usa?
Posts: 14,384 Likes: 30
Posts: 14,384 Likes: 30 |
und erstmal die Frachtkosten.
autoteam-essen.de
Die Verständnis Synapse
Posts: 1,290 |
Was gibts denn da und nur da???
Vergiss USA ohne Kumpel der es dir mitbringt.
------------------------------------------------------------- * Mag jemand sein Hannibal Dachzelt nicht mehr? * -------------------------------------------------------------
HEAVY DUTY REAR AXLE KITS Our late model Rover axles are all manufactured with a special aviation grade alloy steel and all utilize an advanced waisted design that allow maximum flex without breaking. All of these axles have bead blasted final finishes. Most applications come supplied with GBR heavy duty drive flanges. These axles are estimated to be at least 100% stronger than stock axles and are highly recommended for extreme four wheelers, vehicles with oversize tires and/or more powerful engines. All of these axles are 1.25"/24 spline so no machining or custom differentials are required.
(picture)
Applications and Prices Model Kit part # Price Range Rover 1987,88,89 GBRK571882/3 $599 Range Rover 1990 - 1995 GBRK3270/71 $599 Discovery 1994 - 1998 GBRK3270/71 $599 Defender 90 1994 - 1997 GBRK3270/71 $599 Defender 110 1993* GBRK2454/55 $599 *Defender 110's from the factory have a 2 piece axle i.e. separate drive flanges, which can be reused with our axles. The pricing shown includes our special drive flanges - GBR5806.
Posts: 3,890 |
Ca 10% Zoll auf ware und Porto - darauf dann 16% MWSt.
Carsten ;-)
Homo Stupidus
Homo Stupidus
Posts: 12,559 |
with a special aviation grade alloy steel and all utilize an advanced waisted design that allow maximum flex without breaking. na klasse! und was ist das? ist das der gleiche luftfahrtunfug wie bei den "hochklassigen" seilwindenseilen? our antriebswelle is manufactored from 20NiCrMo12, specially hardened and rewarmed........usw usw usw ja dann........... das ganze werbegeschwafel ist deutlichst ohne entsprechende zusage und somit nichtssagend. wer da geld hinterherschmeißt scheint genug davon zu haben
Posts: 3,890 |
BTW: hier gibt es son Kram auch ohne Zoll und Zauber. Mit 5 Jahren Jarantie.
Homo Stupidus
Homo Stupidus
Posts: 12,559 |
absolut nichtsagend.
mich würde mal interessieren ob die verzahnung eingefräst oder eingehämmert ist.
eingehämmert wäre doch ein verkaufsargument!
aber da halten sich alle bedeckt, kochen sie doch alle nur mit wasser
weil wirklich gute teile kosten wirklich gutes geld, also nichts for normal users
Posts: 857 |
Ach Armin, warum musst Du nur immer so gnadenlos Recht haben <img src="/forum_php/images/graemlins/smile.gif" alt="" />
CHEERS
Posts: 11,772 Likes: 22
Posts: 11,772 Likes: 22 |
ja dann........... Mein Lieblingsspruch made by USA ist immer noch; Approved by NASA <img src="/forum_php/images/graemlins/graem-thumbsup.gif" alt="" />
278
Topics44,467
Posts676,457
Members10,141
