Posts: 68 |
Does someone ever added the G463 mirrors at the G460 doors? It looks like this is much work, there must be added a strip to make it more firmly.
Does someone have any tips?
Joost
Archivar
Archivar
Posts: 2,155 |
some pictures ( mirror 463) you will find there , perhaps will be usefully. Hans
Posts: 402 Likes: 1
Posts: 402 Likes: 1 |
Hey! Yes, I´ve done it for two times. You only have to make three holes on the right place and to change the place of the typenumber with silikon. For the heating, I added a special relais and a seperate switch. The joystick (from PKW, warm fixed) got his place between the seats. If you want, I could take some photos on thuesday. Complete, perhaps 4-5 hours.... reed5415
Posts: 68 |
Hallo Reed, If it would be possible i would like to see those pictures. Thanks for your information. mvg, Joost Joost@de-eendenkooi.nl
Posts: 402 Likes: 1
Hei! It is a little bit difficult to translate the following parts: Switch 129 820 0610 Mirror 463 810 1116 Mirror 463 810 1416 Zugschalter 2-polig Relais 1 Stck Stecksicherung mit Halter 1 Stck Kabel 7x1,5 4 Meter Kabel 2x1,5 4 Meter Flachsteckerbuchsen 10 Stck Schaltplan für Anschlüsse elekr. Außenspiegel 463 PE88.79-P-2000-60H But you need only the colours: links.und rechts (both sides): Motor1 ws Motor2 sw/bl Motoren-Masse bl Heizung sw/rt und br
Now there ist a problem with the photos - tomorrow
Good luck reed515
Archivar
Archivar
Posts: 2,155 |
Hei! It is a little bit difficult to translate the following parts: Schaltplan für Anschlüsse elekr. Außenspiegel 463 PE88.79-P-2000-60H Good luck reed515 Hallo reed515, PE88.79-P-2000-60H ist nur die Legende zum Schaltplan, der hat die Nummer PE88.79-P-2000-99H In der WIS ist eine sehr schöne Tabelle der englischen Fachwörter beim G (deutsch-englisch): OV00.01-Z-1005-01AA bis 01ZV Terminologie z.B: Flachsteckersicherung flat pin fuse schau mal in Dein Postfach <img src="/forum_php/images/graemlins/wink.gif" alt="" /> Gruß Hans ![[Linked Image von hehlhans.de]](http://www.hehlhans.de/4x4/spiegel.jpg)
Posts: 402 Likes: 1
Archivar
Archivar
Posts: 2,155 |
Hallo reed515,
Eigentlich könnte man den Schalter mit Relais für die Spiegelheizung weglassen und diese über eine Sicherung direkt an Kl. 15 anschliessen. Das beheizte Spiegelglas wird durch einen Temperaturschalter gesteuert, der ab 25 Grad öffnet und so die Spiegelheizung ausschaltet. Die Heizfolie hat einen Widerstand von etwa 4,7 Ohm, da fließen auch nur max. 2,8 A bei 13 V.
Wie werden die Spiegel über den Drehschalter A1298200610 verstellt? <img src="/forum_php/images/graemlins/confused.gif" alt="" /> Umschaltung??
Gruß Hans
Posts: 789 |
Ich würde die Spiegelheizung einfach mit an die Heckscheibenheizung anschließen . Gruß Jürgen
Posts: 26,667 Likes: 184
Posts: 26,667 Likes: 184 |
Wie werden die Spiegel über den Drehschalter A1298200610 verstellt? <img src="/forum_php/images/graemlins/confused.gif" alt="" /> Umschaltung?? Der Schalter ist wie ein Joystick, bewegbar in alle vier Richtungen. Die Drehfunktion schaltet zwischen den einzelnen Spiegeln um.
396
Topics44,441
Posts676,149
Members10,135
