#530106 21/10/2012 10:16
Hallo verzeilung fur die frage in English. Sie konnen gerne auch in Deutch antworten.
As usual, some promblems/question arise moments before leaving on a big trip. This is the case now, I am packed and ready to leave fo an offroad trip trough Croatia. Takes me 1400km of highway to get there.
The temperature of my G is usually between 85 degrees celcius (opening temp of thermostat) and 90 degrees. When I push it to 120 km/h or higher it might hit 100 degrees and drop down to 90 again when I slow down to around 110 km/h.
Lately It runs a bit higher when I'm on the highway and when I go 110 km/h (my prefered cruising speed for this vehicle) it is around or just below 100 degrees celcius.
The red zone on the gauge starts only at 120 degrees celcius, but that seems ridiculous? I have no time for big repairs, so shoud I worrie driving around 95 / 100 degrees all day.
What I did:
- I drained the coolant fluid and replaced it.
- I replaced the themostat.
Did I do something wrong?
I just filled up the coolant when engine was cold, ran the car until it was hot. Checked coolant level. Now I couls add a liter or so...ran for about 200km. Coolant level stays nicely on maximum. I checked the hoses on top and bottom of radiator and I know the thermostat opens...I can also see the coolant moving around when I look in the radiator with running engine so the pump seems to work fine too. I can find no leaks.
What can I check?
And most of all, can my engine cope with 95/100 degrees celcius!!!!
Thank you very much!
Geoffrey
Das war ein ewiges Thema beim 290TD
Kennst Du die Pläne mit der großen Wasserpumpe und der kleineren Riemenscheibe vom 350TD? Über die Suche "große Wasserpumpe" findest Du hier eine Teile-Liste.
Dass Du nach einem Wechsel noch einmal Kühlflüssigkeit nachfüllen musst, ist normal. Ich hatte bei meinem 290TD extrem sorgfältig mit Vakuum entlüftet, aber trotzdem mußte ich nach der ersten Fahrt noch gut 1,5 Liter auffüllen.
viele Grüße
Tobias
Danke,
Ich plane das mit der grossere Wasserpumpe.
(hilft das wirklich???)
Aber jetzt kein zeit darfur.
Kan ich so fahren mit 95 grad auf die Autobahn?
Die große Wasserpumpe hilft absolut - selbst bei 40°C Außentemperatur mit Klimaanlaage und voll beladener Wagen auf der Autobahn, bleibt die Temperatur des Kühlmittels eigentlich immer unter 100°C. Der Umbau ist einfach und schnell.
95°C Kühlmitteltemperatur ist absolut in Ordnung, da kann es keine Probleme geben.
VG Tobias
Hello
if you would like to increase the performance of the coolant system than use the bigger waterpump from the 350 GD Turbodiesel with 72 mm diameter.
Greetings
hello geoff,
thomas and tobias have mentioned a good way to make the performance of the coolant system better, but what puzzles me, is that your temp has changed.....
have u tried to clean the radiator from lim ? there are somewhere here some really good instructions, i believe
it was the user DAPO who posted them....if u need help finding them, let me know and i see if i can find them for you.....
good luck and a safe trip
chris
greez femo
www.g500.ch
Hello,
Back from a fantastic week in Croatia! (+ 4000 km)
The car had NO problems, but the temperature rose to 95 or 100 degrees when working hard. (uphill on motorway and/or faster then 115 km/h)
We suspected the visco fan, but I would like to be sure. We could hold back the fan with a folded piece of paper with a warm engine, is this normal?
I have a brandnew radiator that I am going to fit too.
Does anyone know how much the visco thing costs?
thx,
Geoff
(sorry for the English)
SBA Offline
S Offline
Grüße aus dem Remstal
Stefan
im Sommer :Renault Grand Scenic 130dCi mit Luxe Vollausstattung im Winter G 270 CDI und noch einen ganzen Stall alter Kisten :-)
(56 Buick/Checker/Talbot Samba/Volvo 66/Checker Aerobus/220 Seb/Avantime und ein Busle O 302)
thx!
G Offline
bei dem Preis würde ich aber selbst noch mal nach der richtigen Visco Kupplung für den Lüfter suchen.
Das müsste auch zum 1/2 Preis gehen in guter Qualität.
Ansonsten git es hier noch den LINK für online Preise (Autohaus Dröge www.online-teile.com )Das wäre original.
MfG vom Main
Elodef
Elodef
Sao Paulo, Brasilien
20,364,177 Hertha`s Pinte
8,027,365 Pier 18
3,789,522 Auf`m Keller
3,732,013 Musik-Empfehlungen
2,754,527 Neue Kfz-Steuer
2,711,877 Alte Möhren ...
0 members (), 369 guests, and 0 robots.
tasso 3
GW350 1
GRR#6
Gclass400cdi, FV111, Herbsti71, daxemuxuxil23, G350TDmax
10,117 Registered Users
DaPo 26,647
Ozymandias 16,759
Topics44,418
Posts675,786
Members10,117
