#61778 27/08/2005 15:16
Hello Iveco drivers !
Yesterday I had a pleasant visit from Iveco and crew from Austria, it is not often that I see you Ivecodrivers from the continent here in Iceland.
I have discovered a slight problem in my truck, water under the floor mat.
I know that you have discussed this before here in the forum, but my german is very poor.
I seemes to me that the water is dripping down under the dashboard in the right side of the cabin.
Have you had the same problem, and what did you do about it ?
Regards ! Þorleifur.
Hallo Thorleifur
it could be that you have a problem with the seal of the frontscreen itself or there is rust under the seal. My Daily is from 1997 and I have to replace the whole franework of the screen to be sure that there will be no more problems for the next years. So first vou should check whether the water comes from the frontscreenseal and if yes,then you have to remove it to solve the problem
Greetings Juergen
We had the same problem like Juergen: remodeling the frame and a new seal solved it.
Gruß Michel
20,748,466 Hertha`s Pinte
8,174,099 Pier 18
3,894,686 Auf`m Keller
3,853,260 Musik-Empfehlungen
2,853,513 Neue Kfz-Steuer
2,824,100 Alte Möhren ...
0 members (), 236 guests, and 0 robots.
WoMoG 6
Padane 2
G300GD 1
atolex 1
mase1, RS-WERKZEUGE
10,169 Registered Users
DaPo 26,719
Topics44,504
Posts676,901
Members10,169
