Posts: 138 |
Hello Iveco drivers !
Yesterday I had a pleasant visit from Iveco and crew from Austria, it is not often that I see you Ivecodrivers from the continent here in Iceland. ----------------------------- I have discovered a slight problem in my truck, water under the floor mat.
I know that you have discussed this before here in the forum, but my german is very poor.
I seemes to me that the water is dripping down under the dashboard in the right side of the cabin.
Have you had the same problem, and what did you do about it ? Regards ! Þorleifur.
Posts: 7,691 Likes: 139
Posts: 7,691 Likes: 139 |
Hallo Thorleifur
it could be that you have a problem with the seal of the frontscreen itself or there is rust under the seal. My Daily is from 1997 and I have to replace the whole franework of the screen to be sure that there will be no more problems for the next years. So first vou should check whether the water comes from the frontscreenseal and if yes,then you have to remove it to solve the problem
Greetings Juergen
Posts: 929 |
We had the same problem like Juergen: remodeling the frame and a new seal solved it.
Gruß Michel
460_2
OldenburgerMuensterland
1 members (WoMoG),
304
Topics44,504
Posts676,899
Members10,169
