on the road
on the road
Posts: 50 |
Yes that is a standard report output from the Turbo test. The EASY will do various engine tests and the give a very detailed report with graphs and also a simple summary stating yes it past or no something is wrong! If you have a problem you should be able to get these reports from your Iveco dealer when they have done diagnostic work on your truck. They are automatically saved on the system so they can reproduce them if you forgot to ask at the time. The only down side to the EASY is the cost! I am travelling to many countries that don't have Iveco garages so it was an important investment for me.
Here is a text report of the turbo test:-
-------------------------------------------------------------------- TURBOCHARGER TEST --------------------------------------------------------------------
Turbo: T. Ref: 89
Amb P (engine off): 1010 Boost P (engine off): 1019 Pos Actuator: Boost P Boost P / Amb P Eng. Speed Q. Fuel 0 1001 0.99 2998 10 1 1001 0.99 3002 10 2 1002 0.99 2998 11 3 1002 0.99 2998 10 4 1002 0.99 3000 11 5 1002 0.99 3001 11 6 1003 0.99 2998 11 7 1003 0.99 3001 11 8 1003 0.99 3001 11 9 1003 0.99 3001 11 10 1005 1.00 2997 11 11 1006 1.00 3002 11 12 1008 1.00 2996 10 13 1009 1.00 3001 10 14 1011 1.00 3002 11 15 1012 1.00 3000 11 16 1014 1.00 2997 11 17 1015 1.00 3004 11 18 1018 1.01 2995 10 19 1020 1.01 3002 11 20 1023 1.01 3000 10 21 1026 1.02 3003 11 22 1029 1.02 2998 11 23 1032 1.02 3002 10 24 1035 1.02 3002 11 25 1039 1.03 3001 11 26 1042 1.03 3000 11 27 1046 1.04 3003 11 28 1050 1.04 3003 11 29 1053 1.04 2996 11 30 1057 1.05 2997 11 31 1061 1.05 3006 11 32 1066 1.06 3001 11 33 1071 1.06 3002 11 34 1076 1.07 2999 11 35 1080 1.07 3001 11 36 1087 1.08 2997 11 37 1094 1.08 2998 11 38 1103 1.09 2994 11 39 1110 1.10 3003 11 40 1120 1.11 3002 11 41 1129 1.12 3004 11 42 1140 1.13 2998 11 43 1152 1.14 3004 11 44 1166 1.15 3006 11 45 1180 1.17 2998 11 46 1189 1.18 3000 11 47 1205 1.19 3002 11 48 1226 1.21 3002 11 49 1249 1.24 3004 11 50 1269 1.26 2996 11 51 1291 1.28 3002 11 52 1312 1.30 2998 11 53 1324 1.31 2998 11 54 1344 1.33 3005 11 55 1365 1.35 3000 11 56 1388 1.37 2998 11 57 1408 1.39 3002 11 58 1428 1.41 2998 11 59 1450 1.44 2996 11 60 1470 1.46 3002 12 61 1486 1.47 2998 11 62 1496 1.48 3003 12 63 1504 1.49 3000 11 64 1509 1.49 3000 11 65 1513 1.50 2995 11 66 1515 1.50 3001 12 67 1517 1.50 3005 12 68 1518 1.50 3002 11 69 1520 1.50 2998 12 70 1521 1.51 3006 12 71 1522 1.51 3004 12 72 1523 1.51 2997 11 73 1523 1.51 2998 12 74 1524 1.51 3002 12 75 1525 1.51 3000 11 76 1526 1.51 3000 11 77 1527 1.51 3000 11 78 1529 1.51 2996 11 79 1529 1.51 3003 11 80 1530 1.51 2998 11 81 1531 1.52 3000 11 82 1532 1.52 3006 12 83 1534 1.52 3000 11 84 1556 1.54 2970 14 85 1601 1.59 2984 14 86 1619 1.60 2999 14 87 1617 1.60 3010 13 88 1605 1.59 3006 13 89 1593 1.58 3021 12 90 1573 1.56 3013 11 91 1563 1.55 3010 12 92 1557 1.54 3001 11 93 1554 1.54 3003 11 94 1552 1.54 3002 11 95 1551 1.54 3003 12 96 1550 1.53 2998 12 97 1549 1.53 3000 12 98 1549 1.53 3000 11 99 1549 1.53 3002 11 100 1550 1.53 3004 12 99 1549 1.53 3000 11 98 1551 1.54 3000 11 97 1551 1.54 3000 11 96 1552 1.54 3004 11 95 1551 1.54 2998 12 94 1552 1.54 3003 12 93 1551 1.54 2998 11 92 1552 1.54 3000 11 91 1552 1.54 3000 11 90 1553 1.54 3000 12 89 1553 1.54 2998 12 88 1553 1.54 3000 11 87 1553 1.54 2998 11 86 1555 1.54 3001 11 85 1554 1.54 3002 12 84 1555 1.54 3001 12 83 1555 1.54 3002 11 82 1554 1.54 3001 11 81 1555 1.54 2998 11 80 1555 1.54 3000 11 79 1556 1.54 3000 12 78 1555 1.54 3003 11 77 1556 1.54 3004 11 76 1556 1.54 3001 12 75 1555 1.54 3002 12 74 1554 1.54 2997 11 73 1553 1.54 2998 11 72 1552 1.54 3002 11 71 1552 1.54 3002 11 70 1552 1.54 3002 11 69 1552 1.54 2997 11 68 1552 1.54 3000 11 67 1552 1.54 3006 11 66 1551 1.54 3000 11 65 1551 1.54 3000 11 64 1551 1.54 3003 11 63 1551 1.54 2999 11 62 1551 1.54 3002 11 61 1551 1.54 3000 11 60 1551 1.54 2997 11 59 1552 1.54 3003 11 58 1552 1.54 3003 11 57 1551 1.54 3002 11 56 1548 1.53 3000 11 55 1543 1.53 2996 11 54 1535 1.52 3000 11 53 1523 1.51 3004 11 52 1505 1.49 2998 11 51 1486 1.47 3000 11 50 1465 1.45 3000 11 49 1445 1.43 3001 11 48 1423 1.41 2999 11 47 1402 1.39 3001 11 46 1380 1.37 2998 11 45 1359 1.35 2997 11 44 1345 1.33 3002 11 43 1326 1.31 2996 11 42 1302 1.29 2999 11 41 1280 1.27 3002 11 40 1260 1.25 2998 11 39 1242 1.23 2998 11 38 1225 1.21 2995 10 37 1210 1.20 2998 10 36 1195 1.18 3000 11 35 1181 1.17 2998 10 34 1169 1.16 2996 10 33 1157 1.15 3003 11 32 1147 1.14 3003 11 31 1138 1.13 3004 11 30 1129 1.12 2998 11 29 1123 1.11 2999 11 28 1115 1.10 2999 11 27 1107 1.10 2996 11 26 1102 1.09 3004 10 25 1096 1.09 2998 11 24 1091 1.08 2998 10 23 1086 1.08 3000 11 22 1081 1.07 3000 10 21 1076 1.07 3002 10 20 1072 1.06 3002 11 19 1068 1.06 3004 11 18 1065 1.05 2998 11 17 1062 1.05 3000 10 16 1059 1.05 3003 11 15 1056 1.05 2997 10 14 1052 1.04 3002 11 13 1049 1.04 3002 11 12 1046 1.04 3003 10 11 1044 1.03 2998 11 10 1042 1.03 3000 10 9 1040 1.03 2998 11 8 1038 1.03 2998 10 7 1036 1.03 3000 11 6 1035 1.02 2996 10 5 1033 1.02 3001 10 4 1031 1.02 3004 10 3 1030 1.02 3000 11 2 1029 1.02 3002 10 1 1030 1.02 3001 11 0 1030 1.02 3004 10
Range:1
->Turbocharger Evaluation<- GENERAL EVALUATION:
SPECIFIC EVALUATION: Turbocharger Actuator: Turbocharger Actuator closes correctly Opening of Turbocharger Actuator : it opens in the correct way Conditions at the beginning and at the end of the test : PI and InjQ conditions are correct Conditions with closed turbocharger actuator : PI and InjQ conditions are correct Conditions with open Turbocharger Actuator : PI and InjQ conditions are correct Curve Hysteresis of the turbocharger actuator: the curve shows a correct hysteresis
Legenda: PI = relative boost pressure InjQ = fuel delivery
on the road
on the road
Posts: 50 |
A lot of people say that old mechanical vehicles are best for overlanding, I don't think so! If you have the diagnostic computer and you take the time to learn how to use it, it is like having a garage full of test equipment and a rolling road all contained in your computer. You can diagnose so much with the computer and the engine protects itself if there is a mechanical fault. Modern electronics is very reliable and I have found most issues are actually down to wiring rather than the boxes on the end of the wires.
on the road
on the road
Posts: 50 |
A quick update on my AFAM development: I have been working hard to improve the software and hardware. I’m working with Don in Australia ( www.goingbush.com) and we are getting really close to being able to offer full constructed and tested AFAM replacements, either as a PCB to put in your original AFAM cases, or as a complete unit in its own case. Here are the new features that I have added in addition to all the normal functionality: 1. When the ignition is turned on, the unit will check the existing state of the locks. If the parameters are still within limits, i.e. vehicle speed and sequence, the lock solenoids will be automatically reengaged as appropriate. If they are no longer required, they can be deselected in the usual manner. 2. If the vehicle is stalled, the unit will remain powered for approximately 5 seconds after the ignition is turned off. This should allow enough time to turn the ignition off and on again, so that the engine can be restarted without any of the selected locks disengaging. 3. To engage more than one differential lock, it is no longer necessary to wait for the previous lock to engage before making the selection. You can now select all the locks you would like and the unit will engage them in sequence as soon as it is possible. 4. To disengage more than one differential lock, it is not necessary to wait for the previous lock to disengage before making the selection. For example, you can now deselect all the locks by simply pressing the ‘centre differential lock’ button. The unit will disengage them all in sequence as soon as it is possible. 5. To engage the rear lock only, stop the vehicle and press and hold the ‘rear differential lock’ and the ‘front differential lock’ buttons simultaneously for about 2 seconds. If the rear lock is the only lock engaged, it will disengage automatically at about 30 kph. The centre lock can be selected and then the front lock selected if required. To disengage, simply press the ‘rear differential lock’ button. 6. To turn off the ABS, press the ‘front differential lock’ button until the small ABS light illuminates. Pressing the ‘front differential lock’ button again will turn the ABS back on. 7. Pressing and holding the ‘centre differential lock’ button until a long beep is heard, will engage the centre differential lock, but the automatic disengagement at speeds above 80 kph will be disabled. I have been testing this extensively through the Amazon in Suriname, Guyana and Brazil and it has so far worked very well; far better than the original. The locks just ‘go in’ when I want them! Here is an example of the kind of conditions in which it has been tested in the Amazon: http://www.tuckstruck.net/driving-the-br-319-with-free-pants-and-a-soup-tin/ Don has also been testing the AFAM in Australia. Here are some videos that he has produced showing its functionality: Video 1 Rear diff lock only operation: https://youtu.be/aIHd6nQYr0o Video 2 Centre, Rear & Front diff lock test: https://youtu.be/U-E_LMzYD3k Video 3 Centre diff lock with speed drop out disabled: https://youtu.be/SX3xD3u_YFY Video 4 Activate Centre, Rear, Front plus auto disengage & ABS OFF: https://youtu.be/VZu3wU0sVPc Once Don has received the ‘production’ batch of PCBs, he will be starting to manufacture them. I will add a link to his website so anyone interested can order them from him. Unfortunately, life on the road means that I can’t really build them for others, but I have been working with Don to fine-tune the circuit design and software.
on the road
on the road
Posts: 50 |
Well the electrical design has improved and so has the software. As I am on the road travelling I am unable to make them for others, however, Don in Australia has taken on the challenge! They are now being built in Australia if anyone would like one, see http://www.goingbush.com/afam.html![[Linked Image von i67.tinypic.com]](http://i67.tinypic.com/vrx91z.jpg)
Posts: 1,443 Likes: 23
Posts: 1,443 Likes: 23 |
Marcus, I have a lever to engage and disengage the center lock, and one button for rear and front lock respectively*. I can engage (and disengage, of course) them at any time any speed, anywhere. What is the disadvantage of my arrangment?
Best regards from southern Austria Wolfgang with "country cucumber" (Landgurke translated word by word into English)
P.S.: None the less I appreciate your skills electronically and mechanically!
*and if I wouldnt be so lazy, I even would have fitted control lamps...
Posts: 2,640 Likes: 90
Posts: 2,640 Likes: 90 |
Du hast einen komplett anderen Antriebsstrang - just forget it (The prototype Wolfgang got in his hands has a completely different drivetrain)
Grüsse/regards Peter
on the road
on the road
Posts: 50 |
I've driven old vehicles with simple mechanical engagement systems, they are great. However, Iveco decided to make it a bit more complicated and added some 'safety' features so you don't damage the drive chain with poor selection choices or loose control of the vehicle driving too quickly with locks in (there are a lot of people out there that don't really understand what they are doing with diff locks - this is probably why Iveco added the electronics). When you go into the maths of the gear ratios and engine torque you quickly realize it is quite easy to damage the front axle. The only problem is the original AFAM computer has really bad software, I am sure the hardware is good but I cant access their PIC to reprogram it. Everyone I have spoken too with the original AFAM complain about how hard it can be to get the locks to engage, it is not the actual looks that is the problem, it is the logic (or lack of it) in the AFAM.
Anyway it is always good to get a bit of banter on the forums :-) I will keep all the electronics and comfort of the modern vehicle over the discomfort of old mechanical clunky trucks......
Me too - but the other way round! Look, I´m 60+ now and I grew up with the advantages (and some disadvantages too of course*) of engineered - and not electronicised - vehicles. When you and I will meet - somewhere, sometime - I will tell you how I managed to come back home from Norway with a front axle CV-joint broken (without diff lock of course) at my ´64 DKW Junior. This was my first (and the only one person mobile home I know) I owned. This one: ![[Linked Image von abload.de]](https://abload.de/img/5ga4follackierth7ady.jpg) was the fourth or fifth (multi person obviousely!!). 4x4 but no locks, neither back or front, center lock was permanent... Our Iceco Prototype seems to be the ultimate vehicle for my wife and me (she´s the one stepping out of the bus). Best regards from a tiny village founded in 12hundredsomehing Woolfe-Gang with the county cucumber *Which? P.S.: I agree about the banter
Posts: 1,100 Likes: 41
Posts: 1,100 Likes: 41 |
Hi Marcus
Congratulation for your great work in this DIY-Project - to find out all functionality and improve it. And you aditionally do a lot of work to give your solution to other Daily users. The circuit PCB has a clear layout helpfully for easy mounting the parts.
But from my professional view as an former developer of automotive circuits (which i can`t stop) i see also some problematic aspects at the PCB - level, which will i give you as information, not critic. I understand this is as an functional circuit - not an commercial automotive product.
my points are: the Arduino socket pin connectors aren't vibrationproof - this kind of connector is never allowed in automotive industrie designs, no powersupply smoothing (is there a powersupply cicuit ?), no Protection for In- and Output pins (with Capacitors, Resistors), no Overvoltage protection for circuit (by Varistors, Transsil diodes, etc),
So if you would get "sold out" and run it at more commercial level you should add such security circuits at next board design. Until this give users the hint to stick the boxconnector never under power.
regards
Erich
on the road
on the road
Posts: 50 |
Hi Eric,
Thanks for the advice it is appreciated. I was also looking to use surface mount components too but they would be very difficult for 'home construction' but would increase the vibration tolerance. To try and reassure you of the design this is what I have done. For the power supply the maximum vehicle voltage according to the Iveco documentation I have is 15.7V - obviously something could go seriously wrong with the alternator and a higher voltage could be produced but that would probably cause other problems too. The Arduino Due power input range is 6 to 16V and it does the voltage regulation 'on-board' (this regulated supply feeds the pull up resistors in the input circuitry to provide stable input signals). However, it is recommend to try and keeping the voltage below 12V so the Due's power circuit does not get too hot. In the power circuit I have added two large diodes, chosen because they have a quite large forward voltage drop, just over the standard 1.2V of a silicone device, so a total drop of over 2.4V. In testing I have not seen the supply voltage to the Due go above 12V or the Due's temperature above 35C, even when it was 30C in the cab driving through the Amazon Jungle with the widows open (I have an LM19 monitoring the systems temperature in the prototype). The Due maximum operating temperature is 85C. The Due is attached to the underside of the board on the header pins but there are also 6 standoffs 'bolting' it to the board so it should be quite vibration resistant (sorry the one in the photo above doesn't have them installed, we are awaiting their delivery). The AFAM box it is mounted in is also on vibration isolators and the box that Don supplies also has a water seal on the lid, something the Iveco one does not have! Four of the six switch signals are open circuit going to ground so I felt that there was little need to protect them and the two signals that switch open circuit to high (actually switching to a supply provided by the AFAM circuit) do so through a resistor potential divider and transistor which could handle an input voltage well in access of 16V. The speed and rpm signals also go through a resistor potential divider and transistor network. I did not design the circuit allowing for someone to start putting 12v where it shouldn't be, although given the quality of Iveco wiring looms that may have been a good idea. The circuit design and software have changed considerably from that shown on my website. The website was very much my first prototype, with version 1.7 software, the ones now being produced in Australia are on the second PCB design and are using version 8.6 software.
Marcus
1 members (1 unsichtbar),
164
Themen44,384
Posts675,497
