Seite 2 von 3 1 2 3
on the road
on the road
Yes that is a standard report output from the Turbo test. The EASY will do various engine tests and the give a very detailed report with graphs and also a simple summary stating yes it past or no something is wrong! If you have a problem you should be able to get these reports from your Iveco dealer when they have done diagnostic work on your truck. They are automatically saved on the system so they can reproduce them if you forgot to ask at the time. The only down side to the EASY is the cost! I am travelling to many countries that don't have Iveco garages so it was an important investment for me.
Here is a text report of the turbo test:-
TURBOCHARGER TEST
Turbo:
T. Ref: 89
Amb P (engine off): 1010
Boost P (engine off): 1019
Pos Actuator: Boost P Boost P / Amb P Eng. Speed Q. Fuel
0 1001 0.99 2998 10
1 1001 0.99 3002 10
2 1002 0.99 2998 11
3 1002 0.99 2998 10
4 1002 0.99 3000 11
5 1002 0.99 3001 11
6 1003 0.99 2998 11
7 1003 0.99 3001 11
8 1003 0.99 3001 11
9 1003 0.99 3001 11
10 1005 1.00 2997 11
11 1006 1.00 3002 11
12 1008 1.00 2996 10
13 1009 1.00 3001 10
14 1011 1.00 3002 11
15 1012 1.00 3000 11
16 1014 1.00 2997 11
17 1015 1.00 3004 11
18 1018 1.01 2995 10
19 1020 1.01 3002 11
20 1023 1.01 3000 10
21 1026 1.02 3003 11
22 1029 1.02 2998 11
23 1032 1.02 3002 10
24 1035 1.02 3002 11
25 1039 1.03 3001 11
26 1042 1.03 3000 11
27 1046 1.04 3003 11
28 1050 1.04 3003 11
29 1053 1.04 2996 11
30 1057 1.05 2997 11
31 1061 1.05 3006 11
32 1066 1.06 3001 11
33 1071 1.06 3002 11
34 1076 1.07 2999 11
35 1080 1.07 3001 11
36 1087 1.08 2997 11
37 1094 1.08 2998 11
38 1103 1.09 2994 11
39 1110 1.10 3003 11
40 1120 1.11 3002 11
41 1129 1.12 3004 11
42 1140 1.13 2998 11
43 1152 1.14 3004 11
44 1166 1.15 3006 11
45 1180 1.17 2998 11
46 1189 1.18 3000 11
47 1205 1.19 3002 11
48 1226 1.21 3002 11
49 1249 1.24 3004 11
50 1269 1.26 2996 11
51 1291 1.28 3002 11
52 1312 1.30 2998 11
53 1324 1.31 2998 11
54 1344 1.33 3005 11
55 1365 1.35 3000 11
56 1388 1.37 2998 11
57 1408 1.39 3002 11
58 1428 1.41 2998 11
59 1450 1.44 2996 11
60 1470 1.46 3002 12
61 1486 1.47 2998 11
62 1496 1.48 3003 12
63 1504 1.49 3000 11
64 1509 1.49 3000 11
65 1513 1.50 2995 11
66 1515 1.50 3001 12
67 1517 1.50 3005 12
68 1518 1.50 3002 11
69 1520 1.50 2998 12
70 1521 1.51 3006 12
71 1522 1.51 3004 12
72 1523 1.51 2997 11
73 1523 1.51 2998 12
74 1524 1.51 3002 12
75 1525 1.51 3000 11
76 1526 1.51 3000 11
77 1527 1.51 3000 11
78 1529 1.51 2996 11
79 1529 1.51 3003 11
80 1530 1.51 2998 11
81 1531 1.52 3000 11
82 1532 1.52 3006 12
83 1534 1.52 3000 11
84 1556 1.54 2970 14
85 1601 1.59 2984 14
86 1619 1.60 2999 14
87 1617 1.60 3010 13
88 1605 1.59 3006 13
89 1593 1.58 3021 12
90 1573 1.56 3013 11
91 1563 1.55 3010 12
92 1557 1.54 3001 11
93 1554 1.54 3003 11
94 1552 1.54 3002 11
95 1551 1.54 3003 12
96 1550 1.53 2998 12
97 1549 1.53 3000 12
98 1549 1.53 3000 11
99 1549 1.53 3002 11
100 1550 1.53 3004 12
99 1549 1.53 3000 11
98 1551 1.54 3000 11
97 1551 1.54 3000 11
96 1552 1.54 3004 11
95 1551 1.54 2998 12
94 1552 1.54 3003 12
93 1551 1.54 2998 11
92 1552 1.54 3000 11
91 1552 1.54 3000 11
90 1553 1.54 3000 12
89 1553 1.54 2998 12
88 1553 1.54 3000 11
87 1553 1.54 2998 11
86 1555 1.54 3001 11
85 1554 1.54 3002 12
84 1555 1.54 3001 12
83 1555 1.54 3002 11
82 1554 1.54 3001 11
81 1555 1.54 2998 11
80 1555 1.54 3000 11
79 1556 1.54 3000 12
78 1555 1.54 3003 11
77 1556 1.54 3004 11
76 1556 1.54 3001 12
75 1555 1.54 3002 12
74 1554 1.54 2997 11
73 1553 1.54 2998 11
72 1552 1.54 3002 11
71 1552 1.54 3002 11
70 1552 1.54 3002 11
69 1552 1.54 2997 11
68 1552 1.54 3000 11
67 1552 1.54 3006 11
66 1551 1.54 3000 11
65 1551 1.54 3000 11
64 1551 1.54 3003 11
63 1551 1.54 2999 11
62 1551 1.54 3002 11
61 1551 1.54 3000 11
60 1551 1.54 2997 11
59 1552 1.54 3003 11
58 1552 1.54 3003 11
57 1551 1.54 3002 11
56 1548 1.53 3000 11
55 1543 1.53 2996 11
54 1535 1.52 3000 11
53 1523 1.51 3004 11
52 1505 1.49 2998 11
51 1486 1.47 3000 11
50 1465 1.45 3000 11
49 1445 1.43 3001 11
48 1423 1.41 2999 11
47 1402 1.39 3001 11
46 1380 1.37 2998 11
45 1359 1.35 2997 11
44 1345 1.33 3002 11
43 1326 1.31 2996 11
42 1302 1.29 2999 11
41 1280 1.27 3002 11
40 1260 1.25 2998 11
39 1242 1.23 2998 11
38 1225 1.21 2995 10
37 1210 1.20 2998 10
36 1195 1.18 3000 11
35 1181 1.17 2998 10
34 1169 1.16 2996 10
33 1157 1.15 3003 11
32 1147 1.14 3003 11
31 1138 1.13 3004 11
30 1129 1.12 2998 11
29 1123 1.11 2999 11
28 1115 1.10 2999 11
27 1107 1.10 2996 11
26 1102 1.09 3004 10
25 1096 1.09 2998 11
24 1091 1.08 2998 10
23 1086 1.08 3000 11
22 1081 1.07 3000 10
21 1076 1.07 3002 10
20 1072 1.06 3002 11
19 1068 1.06 3004 11
18 1065 1.05 2998 11
17 1062 1.05 3000 10
16 1059 1.05 3003 11
15 1056 1.05 2997 10
14 1052 1.04 3002 11
13 1049 1.04 3002 11
12 1046 1.04 3003 10
11 1044 1.03 2998 11
10 1042 1.03 3000 10
9 1040 1.03 2998 11
8 1038 1.03 2998 10
7 1036 1.03 3000 11
6 1035 1.02 2996 10
5 1033 1.02 3001 10
4 1031 1.02 3004 10
3 1030 1.02 3000 11
2 1029 1.02 3002 10
1 1030 1.02 3001 11
0 1030 1.02 3004 10
Range:1
->Turbocharger Evaluation<-
GENERAL EVALUATION:
SPECIFIC EVALUATION:
Turbocharger Actuator: Turbocharger Actuator closes correctly
Opening of Turbocharger Actuator : it opens in the correct way
Conditions at the beginning and at the end of the test : PI and InjQ conditions are correct
Conditions with closed turbocharger actuator : PI and InjQ conditions are correct
Conditions with open Turbocharger Actuator : PI and InjQ conditions are correct
Curve Hysteresis of the turbocharger actuator: the curve shows a correct hysteresis
Legenda:
PI = relative boost pressure
InjQ = fuel delivery
on the road
on the road
A lot of people say that old mechanical vehicles are best for overlanding, I don't think so! If you have the diagnostic computer and you take the time to learn how to use it, it is like having a garage full of test equipment and a rolling road all contained in your computer. You can diagnose so much with the computer and the engine protects itself if there is a mechanical fault. Modern electronics is very reliable and I have found most issues are actually down to wiring rather than the boxes on the end of the wires.
on the road
on the road
A quick update on my AFAM development:
I have been working hard to improve the software and hardware. I’m working with Don in Australia (www.goingbush.com) and we are getting really close to being able to offer full constructed and tested AFAM replacements, either as a PCB to put in your original AFAM cases, or as a complete unit in its own case. Here are the new features that I have added in addition to all the normal functionality:
1. When the ignition is turned on, the unit will check the existing state of the locks. If the parameters are still within limits, i.e. vehicle speed and sequence, the lock solenoids will be automatically reengaged as appropriate. If they are no longer required, they can be deselected in the usual manner.
2. If the vehicle is stalled, the unit will remain powered for approximately 5 seconds after the ignition is turned off. This should allow enough time to turn the ignition off and on again, so that the engine can be restarted without any of the selected locks disengaging.
3. To engage more than one differential lock, it is no longer necessary to wait for the previous lock to engage before making the selection. You can now select all the locks you would like and the unit will engage them in sequence as soon as it is possible.
4. To disengage more than one differential lock, it is not necessary to wait for the previous lock to disengage before making the selection. For example, you can now deselect all the locks by simply pressing the ‘centre differential lock’ button. The unit will disengage them all in sequence as soon as it is possible.
5. To engage the rear lock only, stop the vehicle and press and hold the ‘rear differential lock’ and the ‘front differential lock’ buttons simultaneously for about 2 seconds. If the rear lock is the only lock engaged, it will disengage automatically at about 30 kph. The centre lock can be selected and then the front lock selected if required. To disengage, simply press the ‘rear differential lock’ button.
6. To turn off the ABS, press the ‘front differential lock’ button until the small ABS light illuminates. Pressing the ‘front differential lock’ button again will turn the ABS back on.
7. Pressing and holding the ‘centre differential lock’ button until a long beep is heard, will engage the centre differential lock, but the automatic disengagement at speeds above 80 kph will be disabled.
I have been testing this extensively through the Amazon in Suriname, Guyana and Brazil and it has so far worked very well; far better than the original. The locks just ‘go in’ when I want them!
Here is an example of the kind of conditions in which it has been tested in the Amazon: http://www.tuckstruck.net/driving-the-br-319-with-free-pants-and-a-soup-tin/
Don has also been testing the AFAM in Australia. Here are some videos that he has produced showing its functionality:
Video 1 Rear diff lock only operation: https://youtu.be/aIHd6nQYr0o
Video 2 Centre, Rear & Front diff lock test: https://youtu.be/U-E_LMzYD3k
Video 3 Centre diff lock with speed drop out disabled: https://youtu.be/SX3xD3u_YFY
Video 4 Activate Centre, Rear, Front plus auto disengage & ABS OFF: https://youtu.be/VZu3wU0sVPc
Once Don has received the ‘production’ batch of PCBs, he will be starting to manufacture them. I will add a link to his website so anyone interested can order them from him. Unfortunately, life on the road means that I can’t really build them for others, but I have been working with Don to fine-tune the circuit design and software.
on the road
on the road
Well the electrical design has improved and so has the software. As I am on the road travelling I am unable to make them for others, however, Don in Australia has taken on the challenge! They are now being built in Australia if anyone would like one, see http://www.goingbush.com/afam.html
[Linked Image von i67.tinypic.com]
W&E Offline
Marcus,
I have a lever to engage and disengage the center lock, and one button for rear and front lock respectively*. I can engage (and disengage, of course) them at any time any speed, anywhere.
What is the disadvantage of my arrangment?
Best regards from southern Austria
Wolfgang
with "country cucumber" (Landgurke translated word by word into English)
P.S.: None the less I appreciate your skills electronically and mechanically!
*and if I wouldnt be so lazy, I even would have fitted control lamps...
Du hast einen komplett anderen Antriebsstrang - just forget it (The prototype Wolfgang got in his hands has a completely different drivetrain)
Grüsse/regards
on the road
on the road
I've driven old vehicles with simple mechanical engagement systems, they are great. However, Iveco decided to make it a bit more complicated and added some 'safety' features so you don't damage the drive chain with poor selection choices or loose control of the vehicle driving too quickly with locks in (there are a lot of people out there that don't really understand what they are doing with diff locks - this is probably why Iveco added the electronics). When you go into the maths of the gear ratios and engine torque you quickly realize it is quite easy to damage the front axle. The only problem is the original AFAM computer has really bad software, I am sure the hardware is good but I cant access their PIC to reprogram it. Everyone I have spoken too with the original AFAM complain about how hard it can be to get the locks to engage, it is not the actual looks that is the problem, it is the logic (or lack of it) in the AFAM.
Anyway it is always good to get a bit of banter on the forums :-) I will keep all the electronics and comfort of the modern vehicle over the discomfort of old mechanical clunky trucks......
W&E Offline
Me too - but the other way round!
Look, I´m 60+ now and I grew up with the advantages (and some disadvantages too of course*) of engineered - and not electronicised - vehicles.
When you and I will meet - somewhere, sometime - I will tell you how I managed to come back home from Norway with a front axle CV-joint broken (without diff lock of course) at my ´64 DKW Junior. This was my first (and the only one person mobile home I know) I owned.
This one:[Linked Image von abload.de]
was the fourth or fifth (multi person obviousely!!). 4x4 but no locks, neither back or front, center lock was permanent...
Our Iceco Prototype seems to be the ultimate vehicle for my wife and me (she´s the one stepping out of the bus).
Best regards from a tiny village founded in 12hundredsomehing
Woolfe-Gang with the county cucumber
*Which?
P.S.: I agree about the banter boxing
D
D
Hi Marcus
Congratulation for your great work in this DIY-Project - to find out all functionality and improve it.
And you aditionally do a lot of work to give your solution to other Daily users.
The circuit PCB has a clear layout helpfully for easy mounting the parts.
But from my professional view as an former developer of automotive circuits (which i can`t stop)
i see also some problematic aspects at the PCB - level, which will i give you as information, not critic.
I understand this is as an functional circuit - not an commercial automotive product.
my points are:
the Arduino socket pin connectors aren't vibrationproof - this kind of connector is never allowed
in automotive industrie designs,
no powersupply smoothing (is there a powersupply cicuit ?),
no Protection for In- and Output pins (with Capacitors, Resistors),
no Overvoltage protection for circuit (by Varistors, Transsil diodes, etc),
So if you would get "sold out" and run it at more commercial level you should add such security circuits
at next board design.
Until this give users the hint to stick the boxconnector never under power.
regards
Erich
on the road
on the road
Hi Eric,
Thanks for the advice it is appreciated. I was also looking to use surface mount components too but they would be very difficult for 'home construction' but would increase the vibration tolerance. To try and reassure you of the design this is what I have done. For the power supply the maximum vehicle voltage according to the Iveco documentation I have is 15.7V - obviously something could go seriously wrong with the alternator and a higher voltage could be produced but that would probably cause other problems too. The Arduino Due power input range is 6 to 16V and it does the voltage regulation 'on-board' (this regulated supply feeds the pull up resistors in the input circuitry to provide stable input signals). However, it is recommend to try and keeping the voltage below 12V so the Due's power circuit does not get too hot. In the power circuit I have added two large diodes, chosen because they have a quite large forward voltage drop, just over the standard 1.2V of a silicone device, so a total drop of over 2.4V. In testing I have not seen the supply voltage to the Due go above 12V or the Due's temperature above 35C, even when it was 30C in the cab driving through the Amazon Jungle with the widows open (I have an LM19 monitoring the systems temperature in the prototype). The Due maximum operating temperature is 85C. The Due is attached to the underside of the board on the header pins but there are also 6 standoffs 'bolting' it to the board so it should be quite vibration resistant (sorry the one in the photo above doesn't have them installed, we are awaiting their delivery). The AFAM box it is mounted in is also on vibration isolators and the box that Don supplies also has a water seal on the lid, something the Iveco one does not have! Four of the six switch signals are open circuit going to ground so I felt that there was little need to protect them and the two signals that switch open circuit to high (actually switching to a supply provided by the AFAM circuit) do so through a resistor potential divider and transistor which could handle an input voltage well in access of 16V. The speed and rpm signals also go through a resistor potential divider and transistor network. I did not design the circuit allowing for someone to start putting 12v where it shouldn't be, although given the quality of Iveco wiring looms that may have been a good idea. The circuit design and software have changed considerably from that shown on my website. The website was very much my first prototype, with version 1.7 software, the ones now being produced in Australia are on the second PCB design and are using version 8.6 software.
Marcus
Seite 2 von 3 1 2 3
madmac
madmac
Antwort
20,250,324 Hertha`s Pinte
7,981,362 Pier 18
3,764,347 Auf`m Keller
3,696,972 Musik-Empfehlungen
2,731,332 Neue Kfz-Steuer
2,684,185 Alte Möhren ...
1 members (Gerscher), 183 guests, and 0 robots.
Mickey 65C15, Oachkatzl
Themen44,384
Posts675,497
