#649670 30/03/2017 20:34
T Offline
Where can one buy Brake discs for Iveco Daily 4x4 1991.
Iveco Norway Seller them no more.
Can anyone help me with obtaining them.
Hei
Tore #649672 30/03/2017 21:12
Hei
IVECO really stop selling the Brake Disks Set 1904539 and I don`t know any direct replacement parts so far. No other IVECO has these disks with 303mm.
It seems to be possible to use
Brake disk set 1906300 (⌀ 300mm, 25mm ventilated )
Brake Calliper Perrot left/right 99465472/3
Brake pads 59.12 / 40.10WM 1906183
but this not cheap - you can see an example in this thread
juergenr #679748 11/11/2019 19:38
K Offline
Sorry to bump such an old thread, but does this combination also fit on the WM?
Since the calipers are from the 59.12, would its discs not fit as well?
And do the calipers usually come with the pistons and seals, or do they have another part number?
Thanks for the help,
kldc #679761 12/11/2019 12:51
G Offline
you can make them fit. But the disks don't fit out of the box as they are ventilated and the ones from the WM are not.
Here is another thread about the topic: http://www.viermalvier.de/ubbthreads.php/topics/646370/re-peter-s-wm-40-10-1.html
But you can get some AfterMarket ones here: https://www.gbetech.it/dischi-freno...disc-after-market-.2.33.613.gp.316891.uw
They fit perfectly and you can geth them for about 70-80€!
The calipers are the same as the ones form the Mercedes G-Klasse.
You can get repair kits for them if you only need pistons and seals.
I think I ordered these here: https://www.autoteiledirekt.de/autofren-seinsa-7875921.html
Best,
Grischa
Grischa #679767 12/11/2019 14:37
K Offline
Best,
Grischa
Aha,
So to summarize, to upgrade the WM one can use
Hauptbremszylinder/Bremskraftverstärker 60188878
OR
Brake disks 1904539 AM from Iveco 59.12 (these are single piece (hub + disc), for a 4x2, so this might be a problem??)
Mercedes G-Klasse calipers
Hauptbremszylinder/Bremskraftverstärker 99463713
I want to go for the first option, but since the topic starter was talking about a Daily from '91, wanted to be sure it fits the WM
Grischa #679773 12/11/2019 18:49
K Offline
On closer look, I think those are not from the 59.12 because they have 8 wheel bolts instead of 6.
kldc #679786 13/11/2019 07:30
G Offline
No those are for the 40.10.
Isn't that what you need?
Grischa #679816 13/11/2019 21:19
K Offline
Ja, ein 40.10 WM.
Ich habe es falsch gesehen, ich dachte, das sind die Löcher für die Radschrauben, aber es sind immer noch die für die Nabe.
Aber ich verstehe den Unterschied zwischen 1904539 und 1906300 nicht.
Vielleicht 1906300 ist ein Doppelbremsscheibe und 1904539 nicht? confused2
kldc #679819 14/11/2019 08:20
genau,
die 1906300 ist vom WM (wenn der die stärkere Bremse hat) 300mm Durchmesser, ist 25mm stark und hat einen 4-Kolben Sattel
die 1904539 ist vom 40.10 4x4 und WM (wenn der die normale Bremse hat) 303mm Durchmesser und 16mm stark und diese Scheiben gibt es von IVECO nicht mehr.
Grischa #679821 14/11/2019 08:34
Best,
Grischa
Hallo Grischa,
d.h. du hast die Scheiben 1904539AM in Italien bestellt und ohne Probleme verbaut ?
mb409_4x4
mb409_4x4
Österreich
20,364,053 Hertha`s Pinte
8,027,322 Pier 18
3,789,501 Auf`m Keller
3,731,831 Musik-Empfehlungen
2,754,497 Neue Kfz-Steuer
2,711,850 Alte Möhren ...
1 members (Hartwig), 351 guests, and 0 robots.
tasso 3
GW350 1
Gclass400cdi, FV111, Herbsti71, daxemuxuxil23, G350TDmax
10,117 Registered Users
DaPo 26,647
Ozymandias 16,759
Topics44,417
Posts675,784
Members10,117
