Page 5 of 15 1 2 3 4 5 6 7 … 14 15
Coach
Coach
danke eure Angaben decken sich weitesgehend mit meinen SQL und Server Logfiles und helfen sehr die Performance zu optimieren.
Habe noch mal etwas an den SQL Schrauben gedreht, feedback erwünscht.
Morgen Abend geht das Forum mal für einige Zeit Offline, es werden 12 Updatepakete eingespielt und die Indexe der Tabellen optimiert. Dannach sind auch einige zusätzliche Funktionen im Forum.
Coach
Coach
Hier im Detail die Updates (für interessierte):
Version 6.5.2 is an important maintenance release that contains fixes to many known issues and bugs in 6.5.1.
* Important: The minimum PHP version is now 4.1.
* Extensive form filtering and protection has been add
* You can no longer delete the last category
* New post tracking now works better when linked directly to a topic without visiting the parent forum first
* Post anchors were not correctly formed in expanded view
* Content Islands could contain unapproved posts
* Splitting a topic would not update the topic data correctly
* Newer PHP versions no longer complain about a possible session bug
* New installs should now have proper default settings for the search page
* The edit link is no longer visible to normal users after the edit time has elapsed
* The altertable and createtable scripts were updated to remove syntax that was causing failures under MySQL 4.1
* Fixed a possible failure of the HTML/UBBCode selection dropdown box on the new topic/reply form
* Fixed a possible failure of the edit form to pick up the proper HTML/UBBCode selection from when the post was originally created
* File version checking while performing an upgrade should always detect the proper file versions now
* Unregistered users will no longer get a corrupted date display when certain default settings are used
* Fixed a syntax error in admin/changeuser.php
* Added a filter to the forum keyword field to remove illegal characters
* There should no longer be a form key error after previewing a post
* The Remember Me checkbox will now appear properly in cookie mode
* The "show all" option on postlist should now work properly
* The mailer has been adjusted slightly to include ‘>’ and ‘<’ for cases where they should appear, and exclude them when they should not.
* The mailer has also been adjusted to include the correct number of ‘From:’ headers.
* The sessions directory path setting has been moved in the control panel from it’s old location (primary settings, advanced options) to the paths and URLs tab. It makes more sense for this path setting to be with the rest of the path settings.
UBB.threads™ 6.5.1.1 is a maintenance release that contains the following fixes and updates from version 6.5.1:
* Added additional security checks to the edit post routine.
Version 6.5.1 is a maintenance release that contains fixes to all of the known issues or bugs in 6.5.1. This is the last planned release for UBB.threads.
* Reworked the new post tracking to use session files instead of cookies to eliminate the issue with maximum cookie size.
* Fixed a bug regarding controlling who can vote in polls.
* Fixed a stylesheet problem with new posts in expanded mode.
* Fixed an ordering problem with active topics.
* Fixed a bug where the group management screen does not take permission changes properly.
* Fixed a content island bug not showing the links properly when only one RSS 2.0 feed was created.
* Fixed a bug that was allowing moderators to semi-create global announcements.
* Fixed a bug where deleting global announcements could potentially alter the topic/post counters in the wrong forum.
* Fixed a bug that was preventing admin/mod indicators showing on search results/active topics.
* Re-added the missing feature of updating all the user titles when titles are changed, which also caused the bug of current titles not changing when new post levels are reached.
* Fixed a bug where the categories page was not using search-engine friendly url's to each category, when the option was turned on.
* Fixed a bug that wasn't allowing anonymous users to create a poll even when turned on.
* Fixed a bug that was allowing moved pointers to be edited, which could end up breaking the moved pointer.
* Fixed a bug that would throw a SQL error when editing a user from the CP if the user didn't belong to any groups.
* Fixed a bug where when searching for a username, the username wasn't cached when displaying the searchterms on search result pages.
* Fixed a FAQ bug that was showing an email contact link even if a contact url was specified in the control panel.
* Fixed a text bug where when editing a post and file attachments were turned off where it would still say add or edit an attachment.
* Fixed a bug with the control panel that would remove backslashes from config file settings when performing various actions.
* Fixed a bug where the Quote link was not being closed properly.
* Fixed a bug where passwords were not able to be sent to the user via the CP properly.
* Fixed a bug where search keywords being a part of a URL would sometimes change the case of the link so it wouldn't work properly.
* Replaced a missing check to make sure forum keywords are alphanumeric only.
* Fixed a bug with the private message counter that could potentially display a negative amount of private messages.
* Fixed a case sensitivity bug when checking for reserved names.
* Fixed a bug that was showing the quick reply box and the reply/quote buttons on locked threads.
* Fixed a bug where the categories template brings up cached search results when visiting the newposts in past 24/48/7days links.
* Added a check to make sure fields required at registration time cannot be blanked out when a user edits their profile.
* Fixed a bug where moderators could not delete/edit their own posts in forums they moderate.
* Fixed an admin member search bug that was ignoring searches on users where their last post was made on/before/after a certain date.
* Fixed a bug that would break the extra profile fields if HTML was used in the fields.
* Fixed a bug when clicking search when in a forum, the search didn't default to that forum.
* Fixed a bug with the category field in the boards table not being updated when category names where changed.
* Put a fix in to allow everything to run under PHP 5 properly.
* Fixed a problem with category sorting in a number of scripts.
* Altered the mycookies.php script so it wouldn't allow the user to view/delete the cookies set for underage users.
* Fixed a regular expression bug with censor words containing a forward slash.
* Fixed a regular expression bug with the search engine.
* Fixed a regular expression bug with reserved names
* Fixed a problem that was allowing a category to be selected for content islands, that would result in an error.
* Fixed a password issue with the installer and old crypt() passwords.
* Fixed a problem with an improper keyword showing up in the language editor.
* Fixed a couple of issues with moving threads.
* Fixed an issue with changing post icons where it wouldn't allow the default icon to be changed.
* Fixed a problem where a backup back up all tables would skip w3t_AddressBook.
* Fixed a problem when deleting a user where it wouldn't update the cached total of users.
* Fixed a bug when admins would subscribe users to email digests through the control panel.
* Fixed a number of importer bugs.
* Fixed an issue with the header/footer editor not actually updating the footer.
* Fixed a bug where the user flood control was not working properly.
* Fixed a bug with the AM/PM selections when adding a poll.
* Guest users no longer see lit lightbulbs, as post tracking isn't enabled for guest users.
* Fixed a bug with moving a thread in threaded mode.
* Fixed a bug with locking a thread in threaded mode.
* Fixed a bug with making a post sticky in threaded mode.
* Added some code to make sure a user always belongs to at least 1 group.
* Fixed a bug with username colors not being displayed on search results.
* Fixed a bug where replying from the quick reply box would always send you back to showflat, even if preference was showthreaded.
* Optimized a query in the online.php script
* Fixed a variety of notice/warning errors.
Version 6.5 is a major upgrade, with an entirely new control panel, a new upgrade system, and many new features and refinements.
* Entirely rewrote the control panel from scratch. Every feature was considered, some removed, most expanded cleaned up, or made simpler to use.
* Entirely rewrote the upgrade system to more closely mimic the .classic system, which has been in use for many versions, is widely accepted, and easy to use.
* Entirely rewrote the backup system. UBB.threads no longer requires the presence of, and access to, external system binaries.
* Entirely reworked the search. It is now faster and easier on the server. Admins have more configuration options to further tailor it to their server or use patterns.
* Entirely rewrote the import feature. The import is now compatible with both eve and UBB.classic allowing movement in either direction. We also now have the ability to import from other message board products as well.
* Added Content Islands. The content islands can be created as a server side or PHP include, a JavaScript include or an RSS 0.92, RSS 1.0 or RSS 2.0 feed.
* Added Search Engine Friendly URLs. Switching this on will make all links for the main forum listing, topic listing, and topics search engine friendly. All old style links will continue to work no matter what the setting is. Thanks to Joshpet for the idea.
* Censor list and reserved names list now accept wildcards.
* Data storage for the censoring (badwords, badnames) has been moved to the database.
* Added the ability to limit the number of private messages a user can have.
* Global announcements have been added.
* Flood control system added.
* Allow the admin to use a URL instead of an email address for the contact link.
* Added a stylesheet preview to User's display preferences in "My Home."
* Moved the default location of config.inc.php, theme.inc.php and main.inc.php into the includes folder.
* Added an underline markup tag and added it to the instant ubbcode box.
* Added a stylesheet preview to the display preferences screen.
* Added a signature preview to the user's basic preferences screen.
* Added new flood control protection. A default time between posts can be set on a global basis and also set on an individual basis.
UBB.threads™ 6.4.4 is a minor release that contains the following fixes and updates from version 6.4.3:
* Added additional security checking to the edit profile routines.
* Fixed a bug in ubbt.inc.php which was causing us to not be compatible with php5.
UBB.threads™ 6.4.3 is a minor release that contains the following fixes and updates from version 6.4.2:
* Added additional security checking to the delepost routines.
* Fixed a bug in the edit profile routines.
* Fixed a broken link in the postlist.php template.
UBB.threads™ 6.4.2 is a minor release that contains the following fixes and updates from version 6.4.1:
* Fixed a bug that was preventing sticky posts from being shown when not viewing all topics in a forum.
* Fixed the bug that was preventing the dobecomeuser script from functioning.
* Resolved some minor security issues in polls and markup code.
UBB.threads™ 6.4.1 is a maintenance release that contains the following fixes and updates from version 6.4.0:
* Fixed a bug that allowed anonymous users to make their posts sticky.
* Made a change to force a default group if nothing was selected in the config file.
* Made some changes to make sure the scripts for updating profiles were being called from the profile editors.
* Changed one of the indexes on the posts table to help with speed.
* Fixed a bug with the cron/php/subscriptions.php file that wasn't allowing it to send out HTML emails properly.
* Fixed a bug in the categories page that wasn't showing the proper icons when there were new posts in the category.
* Fixed a bug that was showing the "Add Signature" box for users that weren't logged in.
* Changed the default search range to 1 week instead of all dates, since searching on all dates can slow the forums down.
* Fixed an issue that was preventing HTML emails from being sent out properly in some cases.
* Made a change so the jump to box defaults to the current forum.
UBB.threads™ 6.4 is a major version release that adds the following changes:
* Added in an option to save database queries that are used frequently from the admin section.
* Added in an option to delete a group that is no longer needed.
* Reworked the entire poll system to the style of UBB.classic, this supports multiple questions within a single poll, options for users to vote for more than 1 option, start/stop time and a few other options.
* Added a calendar system that can be used for showing public/private events and birthdays.
* Added a configuration option that allows admins to choose which user groups can add public events to the calendar.
* Added a new profile option for birthdate, along with a setting to have this displayed in the user's public profile, and in the calendar.
* Added a preference that allows users to choose what format they want their times displayed in.
* Added a modification to only show a homepage icon on the member list to prevent long url's from stretching the tables. (thanks JoshPet)
* Added a column to display the user's avatars on the member list.
* Added an option to show the user's age when displaying birthdays.
* Added an option to show today's birthdays on the main forum listing.
* Modified the online table to allow for showing the number of users viewing each forum on the main ubbthreads page without adding any extra queries.
* Added an option to user's public profile pate to ignore that user. Posts from ignored users will still be shown to preserve the flow of a conversation, however the body of ignored user's posts will be set to "You are ignoring this user.
* Added a new option to allow users to select from a predefined set of avatars for their picture.
* Added an option when creating/editing a forum to select an image to be displayed next to the forum on the main page.
* Added a birthday image next to the user's username on showflat/showthreaded when it is their birthday.
* Added a new option when creating a main topic that creates a calendar event for a specified day for that topic. Events will not be displayed on the calendar if the topic is in a forum that a user doesn't have read access to.
* Reworked the search engine. New options include searching only subjects or subjects and body. Searching for keywords by a particular user. Searching between a date range, older than a certain date, newer than a certain date. Showing a preview of the post body with the results. More complex searches using + (required word) and - (posts that don't contain a word).
* Cut 2 queries out of postlist.php for efficiency.
* Cut 1 query out of showflat.php for efficiency.
* Cut 1 query out of showthreaded.php for efficiency.
* Cut another query out of showflat.php if there are no unread posts in the thread.
* Made some modifications to the indexes on the Posts table. This will substantially reduce the number of rows needing to be searched on the postlist/showflat/showthreaded screens.
* Added option to make a post sticky when creating it by selecting a checkbox.
* Moved all thread management tools, move thread, stick/unstick thread, delete thread, (un)lock thread and (un)keep thread out of the edit post screen and down to the bottom of showflat/showthreaded.
* Added an option for users to choose if they want their signature attached to a post when creating it or editing it.
* Added in a config option so admins can specify how long users are displayed in "Who's Online" after they have been inactive.
* Modified movepost/movethread so it returns you to the original forum instead of the forum you moved the post/thread to.
* Reworked the forum listing under the subscriptions portion of the user profile so it lists what category each forum belongs to.
* Created a new send_mail function for sending out emails. Modifed each script that sends out email to call the function instead of mail() directly.
* Created a ubbt_setcookie function that all cookies are now set with.
* Made some changes so posts with polls in them can be edited. The poll itself is not editable, but any text within the post will be.
* Added a maintenance section into the "My Home" area. Added a link to the "My Cookies" utility and move the "Mark all Read" from the navigation bar into this section.
* Reworked the navigation menu. Added a welcome username line and made the nav links into 2 lines to prevent stretching on lower resolutions.
* Made it possible to make a post without a post icon.
* Added new config options to designate the total # of views or replies for a hot topic.
* Added a new table cell on the postlist page to display the hot topic icons, sticky posts, posts with polls, closed topics, or posts with attachments.
* Added a new icon on the postlist screen in the new table cell that helps designate topics that are attached to a calendar event. (thanks JoshPet)
* Added a configurable caching system to cache some things that don't change that often. At this point, that includes total # of users, newest user and today's birthdays. This cuts off 3 queries from the main page when used.
* Added the configuration for the cache settings into the admin -> editconfig area.
* Using the new caching table, added a stat to the main page that shows the max # of users that were ever online.
* Added a new option into the admin section to add/remove from the list of available avatars users can choose from.
* Added a new option into the admin section to add/remove from the list of forum images that can be selected when creating/editing a forum.
* Added the name of the person that created the calendar event when viewing events for a particular day.
* Added a pagination routine to simplify jumping between pages within a forum.
* Added a new icon that designates a moved thread. (Thanks JoshPet)
* Changed the red sticky icon to a yellow one to match the color of the stock icons. (Thanks to Joshpet for the image)
* Made some changes so an admin user can change their display name without going into the display name change que.
* Made some changes so admin users can have special characters in their display names even if they are turned off for normal users.
* Made changes so the first user (main administrator) to register can have any special characters they want in their display name even if it's turned off in the config file.
* Added an admin config option to enable/disable the display of birthdays on the calendar.
* Added a display length limit for the location field on showflat/showthreaded to keep people from scewing the display width. (thanks JustDave).
UBB.threads™ 6.3.2 is a minor maintenance release that contains the following fixes and updates from version 6.3.1:
* Fixed a bug that would appear when editing user profiles with that had colors in their signatures.
* Fixed a bug when editing the language files with the admin editor that would cause extra slashes to be inserted into some of the strings.
* Fixed a bug that would cause a warning message to be displayed when trying to do a database restore from the admin section.
* Fixed a warning message when editing the theme file.
* Fixed a problem with the template editor that was adding extra lines after the closing php tags in the templates.
UBB.threads™ 6.3.1 is a minor maintenance release that contains the following fixes and updates for version 6.3:
* Fixed a bug with multiple categories.
* Fixed a bug with the code tag not working.
* Fixed a sql command bug when approving posts.
* Fixed a sort/page bug with the showmembers script.
* Fixed a bug in showprofile when users had a https address for their homepage.
* Fixed a bug that was preventing the donotifymod emails from going out properly.
* Fixed a bug with the multiple email address check and the changebasic.php script.
* Fixed a bug with doassignmod.php not giving the confirmation list of forums the user has been assigned to.
* Fixed a bug with a few scripts linking to the old style faqs.
* Fixed a bug with users sometimes being directed to pages with no posts.
* Fixed a bug with some of the extra profile files not escaping quotes properly when editing profiles.
* Fixed a bug with the showmembers.php script not handling homepages with https correctly.
* Fixed a problem with the confirmation screen when approving new users.
* Fixed a template bug in the myhome.tmpl.
* Fixed a confirmation screen error when granting admin privs to a user.
* Fixed a parse error in hungarian/editdisplay.php.
* Fixed admin/sendemail.php (english) language typo.
* Fixed logic bug in viewboard/createboard.php.
* Removed extra get_input from ubbthreads.php.
* Fixed a missing "=" in banuser.php, all languages.
* Fixed missing signature separator in addpost.php
* Fixed postlist php XHTML compatibility.
* Updated the altertable-demo, the COPPA flag and mailertable were missing.
* Fixed a bug in the perl cron scipts that would strip linefeeds from HTML email.
* Fixed the httpd header to properly set the charset as defined in generic.php.
* Fixed big5 to the proper charset header.
* Changed to a more tolerant valid email address regex to allow for two and four letter TLD (.cc for example).
* Changed the mailer engine for the perl based cron scripts to a simplified verion of the UBB.classic mailer.
* Changed the mass email options on registration.
* Added opt out link to the bottom of all mass emails sent by the board.
* 6.3 is a major release that adds the following new features, including:
* Moved all text in the administration into language files.
* All language files are now editable through the admin section.
* Added an option into the admin section to activate/deactivate languages. This allows for easy addition/removal of languages.
* Added an option to the mass mailer to send out emails one at a time on servers where Bcc mailing does not work.
* Added in the last poster for each thread when viewing the postlist screen.
* Added a modification of JustDave's "My Cookies" modification, with a template file, which allows users to delete all cookies from a UBB.threads site.
* Modified the banuser function so a user cannot login at all when they are banned.
* Modified showflat/showthreaded so the Board= portion isn't needed when linking to a post. This will keep bookmarks or links to posts that have been moved from breaking.
* Updated the COPPA registration and handling.
* Added the ability to add a custom charset or text direction for a language via the control panel.
* Fixed a bug with linebreaks getting messed up when editing a post under Mac OS 9.
* Fixed a SQL error when deleting all traces of a user.
* Fixed a sorting bug when viewing the address book.
* Fixed a SQL error in addons/ubbttopthreads.php
* Fixed a problem with forums not showing on main page when deleting all posts from a user or deleting a user.
* Fixed a problem with forums not showing on main page on certain occasions when cron/doexpire is run.
* Fixed a bug that would pop up if a post was moved while a user was replying to it.
* Fixed a problem with the mass mailer sending out duplicates on some servers.
* Fixed a bug that caused the year a user registered not to show.
* Fixed a bug with the instant ubbcode when previewing a reply to a private message.
* Fixed a bug with the userlist not showing all users properly.
* Fixed a bug that was causing the post icon to not show up on the main forum listing.
* Fixed a bug when leaving a pointer behind on a moved post made by an anonymous user.
* Added in a check to see if a thread is locked before allowing a user to edit their post.
* Added in Picture size checks into the printthread script.
* Made some changes to showflat to add back in the [Re: Username] next to the subject.
* Combined the welcome email in the adduser language file into 1 string instead of 3 seperate strings.
* Made some changes to deletepost.php, so when deleting the last post in a thread the last poster would update properly for that thread on the postlist screen.
* fixes a potential security flaw that was spotted by one of our users. This only effects 2 files, ubbt.inc.php and /admin/editconfig.php
Danke so kann man uns auch zum Schweigen bringen..... <img src="http://www.viermalvier.de/forum_php/images/graemlins/graem-thumbsup.gif" alt="" />
Da brauch man ja nen Duden zum Frühstück... <img src="http://www.viermalvier.de/forum_php/images/graemlins/klugscheiss.gif" alt="" />
Aberdankedaswirdarübergesprochenhaben <img src="http://www.viermalvier.de/forum_php/images/graemlins/thankx.gif" alt="" />
hexchen
neo Offline
Fahnenflüchtiger 4wd'ler
danke für dein update phil. im moment isses ganz ok, wenn auch nicht wahnssinns schnell, hier is 1300 müsste in d 0700 sein?
wird also wohl doch an der menge der benutzer liegen, grh doch doe sql schrauben mal bis an anschlag, aber immer dran denken, nach fest kommt ab <img src="http://www.viermalvier.de/forum_php/images/graemlins/graem-fuck_you.gif" alt="" />
ansonsten hätt ich da mal noch ne doofe frage, lizenz für forum? gibts sowas ned kostenlos? habt ihr schonmal probiert ob eine andere forensoftware vielleicht schneller ist?
an der hardware kann es ja wohl kaum liegen, ausser die festplatten wäre zu lahm, was ich mal nicht denke das ihr da mist gemacht hat. aber vielleicht ist es ja einfach die software, who knows....
happy <img src="http://www.viermalvier.de/forum_php/images/graemlins/hack.gif" alt="" />
see ya, mate,
neo
....der flüchtige 4wd´ler
7:38
geht ganz ordentlich.
Ist die ICQ Funktion die Spassbremse ??
12:50
Forum läuft prima <img src="http://www.viermalvier.de/forum_php/images/graemlins/graem-thumbsup.gif" alt="" /> <img src="http://www.viermalvier.de/forum_php/images/graemlins/graem-thumbsup.gif" alt="" /> <img src="http://www.viermalvier.de/forum_php/images/graemlins/graem-thumbsup.gif" alt="" />
L
L Offline
Jau, im Moment nicht schlecht - aber auch nie so wie es mit ADSL sollte. Erstaunlicherweise bin ich schneller unterwegs wenn ich nicht eingeloggt bin. Aber sobald ich drin bin....uuuuuuuuuuuuuuuuuuuuuffffffffffffff...
Gruss (neeee... nicht alle Schweizer mögen's langsam <img src="http://www.viermalvier.de/forum_php/images/graemlins/grin.gif" alt="" />)
Coach
Coach
Hi Neo,
Die Differenz zwischen Donnerstag (8300) und Dienstag (9800) sind lediglich 1500 Besucher/Tag .
Daher drehe ich langsam an die sql Schrauben (Try and eror<img src="http://www.viermalvier.de/forum_php/images/graemlins/grin.gif" alt="" />)
Kostenlose Forensoftware, ja das habe ich mir seinerzeit auch schon mal überlegt, aber die Vorteile dieses Produktes einer kostenlosen bevorzugt.
Der Support ist sehr gut, die ausgelieferten Versionen stabil, es ist weniger verbreitet ergo weniger anfällig für Hacker. Das KO für die anderen Boards liegt im wesentlichen im Administrationsbereich.
PhPb ist das weitest verbreitete Board (kostenlos) aber auch eins der am meisten gehackten.
Daher bezahle ich gerne die Lizenzgebühren
Coach
Coach
erst mal n8 brauche ein paar stunden Schlaf.
aktuelle Bugs:
* Grämlin und Link Funktion nicht aktiv
* Deutsche Bedienung muss Teilweise noch übersetzt werden
* Benutzerstatistik auf Startseite stimmt nicht (user vorhanden)
* Kalender einbinden
* VMV Grafik im Header wieder einbinden
* deutsche FAQ unter Hilfe einbinden
Moin hexchen hat wieder Probleme ... wie immmer ... warum gehn die smilies nich mehr ....
danke danke danke
hexchen
[color:"red"] Antwort Phil Bug Gefixt [/color]
20,849,858 Hertha`s Pinte
8,198,992 Pier 18
3,906,546 Auf`m Keller
3,876,002 Musik-Empfehlungen
2,877,885 Neue Kfz-Steuer
2,848,565 Alte Möhren ...
2 members (typfred, 1 invisible), 763 guests, and 0 robots.
Gwalli
10,194 Registered Users
Topics44,521
Posts677,048
Members10,194
