Posts: 16,049 |
Hmmm, kommt wohl keine Antwort mehr... :-( Eine andere Info: Ab der Motornummer 19J27515C wurde beim TD der Zylinderkopf geändert. Davor war es ein 12J Motor mit "anbauten" Zitat von glencoyne 2495cc turbodiesel, overhead valve, type 19J: Given the strength and reliability of the 2.5 diesel, you can understand why Land Rover thought it would cope with turbocharging, but the result was a warranty nightmare. 2.5TDs can fail in any number of ways, but the most common seems to be internal cracks developing in the cylinder block. This gives the same symptoms as a blown head gasket or cracked cylinder head, but is not repairable. Due to a defective design of crankcase breather, these engines also tend to dump large amounts of engine oil into the air filter housing, which turns the paper air filter into a soggy black lump. This in turn leads to oil being drawn into the air intake, causing the engine to 'run away' and self-destruct. Land Rover introduced a new cylinder block for the 2.5 Turbodiesel (part no. ERR479) from engine number 19J27515C. I have not been able to confirm, but suspect that this block was strengthened to get round the block cracking problems I would consider rebuilding a later engine, but not one of the earlier ones. In general, if the vehicle itself is any good, the sensible thing to do is to upgrade to a 200TDi (see below), or for old and tatty TDs the 2495cc non-turbo engine is a very straightforward swap, with only the air intake hose and exhaust system needing to be changed. Ein anderer Beitrag aus einem Englischem Forum der sich damit beschäftigt.
Posts: 16,049 |
da ist mir ein Fehler unterlaufen...
Der Zylinder Block wurde geändert und nicht der Kopf ( cylinder head )
293
Themen44,261
Posts671,836
Mitglieder9,902
