Posts: 1 |
Where can one buy Brake discs for Iveco Daily 4x4 1991. Iveco Norway Seller them no more. Can anyone help me with obtaining them.
Hei
Posts: 7,479 Likes: 106
Posts: 7,479 Likes: 106 |
Hei IVECO really stop selling the Brake Disks Set 1904539 and I don`t know any direct replacement parts so far. No other IVECO has these disks with 303mm. It seems to be possible to use Brake disk set 1906300 (⌀ 300mm, 25mm ventilated ) Brake Calliper Perrot left/right 99465472/3 Brake pads 59.12 / 40.10WM 1906183 but this not cheap - you can see an example in this thread
Posts: 75 Likes: 1
Posts: 75 Likes: 1 |
Sorry to bump such an old thread, but does this combination also fit on the WM? Since the calipers are from the 59.12, would its discs not fit as well?
And do the calipers usually come with the pistons and seals, or do they have another part number?
Thanks for the help,
Posts: 75 Likes: 1
Aha, So to summarize, to upgrade the WM one can use Brake disk set 1906300 (⌀ 300mm, 25mm ventilated ) Brake Calliper Perrot left/right 99465472/3 Brake pads 59.12 / 40.10WM 1906183 Hauptbremszylinder/Bremskraftverstärker 60188878 OR Brake disks 1904539 AM from Iveco 59.12 (these are single piece (hub + disc), for a 4x2, so this might be a problem??) Mercedes G-Klasse calipers Brake pads 59.12 / 40.10WM 1906183 Hauptbremszylinder/Bremskraftverstärker 99463713 I want to go for the first option, but since the topic starter was talking about a Daily from '91, wanted to be sure it fits the WM
Posts: 75 Likes: 1
On closer look, I think those are not from the 59.12 because they have 8 wheel bolts instead of 6.
Posts: 432 Likes: 12
Posts: 432 Likes: 12 |
No those are for the 40.10. Isn't that what you need?
Posts: 75 Likes: 1
Ja, ein 40.10 WM. Ich habe es falsch gesehen, ich dachte, das sind die Löcher für die Radschrauben, aber es sind immer noch die für die Nabe. Aber ich verstehe den Unterschied zwischen 1904539 und 1906300 nicht. Vielleicht 1906300 ist ein Doppelbremsscheibe und 1904539 nicht?
genau,
die 1906300 ist vom WM (wenn der die stärkere Bremse hat) 300mm Durchmesser, ist 25mm stark und hat einen 4-Kolben Sattel
die 1904539 ist vom 40.10 4x4 und WM (wenn der die normale Bremse hat) 303mm Durchmesser und 16mm stark und diese Scheiben gibt es von IVECO nicht mehr.
Hallo Grischa, d.h. du hast die Scheiben 1904539AM in Italien bestellt und ohne Probleme verbaut ?
1 members (toyotom),
568
Posts671,710
